Question about iLO (2 GB) MP3 Player
My ilo wont turn on
It stays at the 20% screen then it goes back to the ilo screen
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Aug 27, 2009 | Mitsubishi WS-55311 55" Rear Projection...
Junk tv
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Apr 02, 2008 | iLO V27DMBX Television
ILO wont start all the way
Reset
Dec 25, 2007 | iLO (2 GB) MP3 Player
Ilo wont play songs but turns on
Everyone has that problem!!LOL that same thing happened to me earlier. i would plug it back in and then unplug it and see if it works.
Dec 12, 2007 | iLO (2 GB) MP3 Player
Ilo freezes
Get an iPod says Good friend from Kelly Elementry
Nov 09, 2007 | iLO (2 GB) MP3 Player
Won't go past ilo screen
I had the same problem I took it back to Walmart for a new one.
Oct 24, 2007 | iLO (2 GB) MP3 Player
Will not turn on
Check the batteries, when you plug in to computer, does it comes on and stay?
Sep 01, 2007 | iLO (2 GB) MP3 Player
ILO MP3 player not working
http://www.lenoxx.com/2005/mp3player/mp556.htm if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
Aug 20, 2007 | iLO MP3 Player
MP3
i having that same problem and im trying to figure that out
Apr 10, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
18 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
