Question about Dehumidifiers
I have a Whirlpool Gold dehumidifier with the hose set up for direct water release into a sink drain. I assumed once you hooked up the manufacturer hose provided it would be a direct drain process and water would not collect in the normal catch basin. Is there a switch or someting to make the water come out of the hose instead of going into the catch basin which fill up quickly?
I have a similar Whirlpool dehumidifier and a similar problem. Have you tried setting it to continuous mode? My understanding was that it would only divert the drainage to a side hose when in the continuous mode.
Posted on Aug 03, 2010
Once you punch a hole in the receptacle, what type of screw cap would fit.
Most of the hose/drain connections i have seen on these have a std gardenhose fitting so you can use a std garden hose to direct the water over to drain, caps for garden hoses are easyly available from any garden supply store , but i do caution you on your thought process of hooking up a hose makes this a maintence free option, it does not as hose and filters still need constant cleaning , especally in high humidity seasons
Sep 09, 2014 | Whirlpool AD40DSL Dehumidifier
How do I connect my dehumidifier with a hose directly to a drain
Are you much of a handyman? Most folks set their dehumidifier on a counter or elevated and run the exhaust tubing right into a sink or toilet. You could collect the water to flush a toilet or water the grass if you are handy. I've never seen anyone connect directly to a drain though.
Jun 04, 2014 | Comfort-Aire BHD-501 Dehumidifier
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
There was a build-up of a snotty white substance in the hose which blocked it from draining. Any idea what this substance could be?
That is an Algae that will grow in damp places... like the dehumidifier hose...
No major problem... just clean the hose with fresh water or replace the hose...
heatman101
Sep 05, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
I have a Maytag M7DH65B2A. I hooked up a hose to
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 20, 2009 | Maytag M7DH65B2A Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
LG dehumidifier won't drain through hose anymore.
Make sure hose is flat with no high or low spots. Blow or **** out hose and pour somr bleach water through hose.
Jun 30, 2009 | LG LD65EL Dehumidifier
Dehumidifier emptys in the floor.
Check the float first - be sure the styrofoam on the bottom is still intact.  Be sure that you can move it up and down freely (and easily) with the bucket out of the machine.  If that is not bound up, and the foam is in place, next check the switch in the dehumidifier itself.  It's directly behind where the float goes - the way to test it is to turn the dehumidifier on and push the metal tab in with your finger.  The machine should cut out immediately - if it does not - the microswitch needs to be replaced.  (they're very cheap, and simple to replace)
Sep 13, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
456 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
