Question about Pro RX65 Radar Detector
Off and on
It turns itself off and back on when driving down the road.
  • sjrb Apr 22, 2008
    Yes, the power is on and obviously the vehicle ignition is on. It happens when I am driving down the interstate. I have also checked the lighter socket and tried it in another vehicle and the same happens.
    Genius:
  • 3,422 Answers
Radar detectors will not work behind heat reflective glass. Note this is different to heated glass found in Fords etc which are fine. The Heat reflective glass as found in most Renaults, Some Peugeots, Citroens etc will effect any gps device also as it inhibits the signal sent to the satellite. In this instance a Re-Ratiating or external antenna is required and can be fitted near the dotted area around the rear view mirror.
I'll also see if there is a manual available for this model and post it here.
Goodluck,
Pleased don't forget to rate the solution.
Posted on Apr 22, 2008
  • 1 more comment
  • Priya darshan Apr 22, 2008
    Check that the power is ON.
    • Check that vehicle ignition is ON.
    • Check that vehicle lighter socket is functional.
    • Try RX65 in another vehicle.
    Please CLICK HERE for the manual.
    If you still face the problem you'll have to get it serviced o replaced if it is still under warranty.
    OK,So i believe you will have to get this serviced.You can look into the link which i gave you for the manual.
    Goodluck once again..
2004 After about a mile of road travel, why does transmission begin to slip?
Usually a transmission slipping isn't due to the drive shaft, but the transmission itself. I know this might sound a like a crazy question, but have you checked the transmission fluid levels, could be a leak, if not full would cause slippage.
Sep 01, 2015 | Honda CR-V Cars & Trucks
Radio turns on by itself while driving down the road
Take radio fuse out and clean terminals or replace fuse.
Mar 27, 2014 | 2000 Chevrolet Silverado 1500
Mazda Astina 1991
Find level ground with a wall. Drive up to the wall and mark where the centre of your headlights are on the wall with a piece of tape. Back up 20 feet and turn your headlights on high beam. Using the adjusting knobs make each light shine directly on the spot. Low beam adjusts itself down and to the left/right (away from oncoming traffic depending on what side of the road you drive on)
Nov 17, 2013 | Ford Cars & Trucks
2008 chevy uplander radio turns on byitself
You will need to dealer to scan the system to see what is causing this.
Aug 26, 2012 | OEM 2008 Chevy Uplander Radio / CD Player...
Hello I have a 2006 Ford Five Hundred, a wrench looking symbol has popped on when I am driving up hill. And when coming back down my RPM's have gone crazy and I have stopped the car, turned it off and when...
You have a transmission control unit problem unfortunately and I'll warn you - it's not cheap. Your description describes it to a "T". It will reset itself to "LIMP" mode (short distance drivability) and will only reset so many times. You need to take to Ford and have trans control unit replaced. (PS bring your wallet - sorry)
Mar 14, 2011 | 2005 Ford Five Hundred
My car turned itself off while driving, now it just turns over
Have the battery charge and have alternater output ck'ed. Should charge at 13.6 to 14.2v
Jun 30, 2009 | 2003 Pontiac Grand Am
2003 Chevy Malibu. While driving down the road turn signal keeps clicking randomly.
what this means that either you have a short in the wire harness going to the turnsignal/dimmer switch assembly . or the switch contacts inside the dimmer switch itself are shorting. this would be a good place to check for the intermitant problem
May 09, 2009 | 2003 Chevrolet Malibu
Device can not "locate" correctly
Turn it on and let sit until it locates itself mine does the same thing only when moving down the road but when I stop it seems to work itself out and then works fine till I turn it on going down the road again
Feb 23, 2007 | Magellan RoadMate 300 GPS Receiver
Pro RX65 Radar Detector Logo
255 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
