Question about Apple iPhone Smartphone
Touch sensitivity 10 % lower screen using 1.1.4
Hi, i saw there are a lot of people out here with the same problem as mine.
How could i get a software or something to increase sensitivity on my iphone v 1.1.4? in order to use that 10% of the screen that currently does not work. would 2.0 version be a solver?
  • Anonymous Feb 07, 2009
    here's my a problem...i patched the new general.plist file and went into settings to increase the screen sensitivity but my dead strip is right on the part where i need to increase the sensitivity. thus i can't move the cursor to different setting. please help....
There is an imperfect fix for this. Go to http://limitededitioniphone.com/iphone-touchscreen-fix-increase-sensitivity/    and read what it says. Basically, you have to release the "touch" feature in the "General" setting. In order to do this you have to load a new version of the file, "General.plist". In order to do THAT, you have to be able to access your iphone files over your wireless network. This means you have to install an SSH application on the iphone. First step, download the altered version of General.plist off the link on the site.
Still with me? OK. In order to install applications on your iphone, you have to jailbreak it, as they say. This can be done very easily for 1.1.4 using iLibertyX. You can find it on the internet. Go to http://modmyifone.com/forums/news/86791-ilibertyx-premier-iphone-itouch-jailbreaking-unlocking-activation-os-x.html    for example. Run the program after syncing your iphone on itunes. When you run the program it will quit itunes automatically. When you are asked what you want to do, choose ONLY the option "jailbreak." Forget all the others, both under the Standard and the Payloads tabs. After jailbreaking the installer program will be installed on your iphone with its own pretty little icon.
As far as I am concerned, the next step is to install Cydia. This is a very nice interface that replaces the installer and works very well for installing stuff. Follow the very complete instructions by the author at http://www.hackthatphone.com/114/iphone_cydia.html.  After you have installed Cydia and Mobil Terminal, as described at the site, go into the list of installable applications and also install "OpenSSH."
Now all you have to do is use Transmit or Cyberduck or whatever FTP program you choose to access the files on your iphone. You will need some basic info about your iphone's network setup. Go into the Settings>General>Network area and touch your wi-fi panel to open the description of your setup. The hit the arrow with the blue circle around it and it will tell you your IP address. Make a note of that number.  Let's say you are using Transmit. In the "Server" field put your IP number. In the "User Name" field put the word "root" (no quotes, of course). In the "Password" field put the word "alpine". As a protocol choose SFTP. Then hit the connect button and it should work. It should show you your iphone files on one side, your desktop on the other. Go to Applications>Preferences.app and find the "General.plist" file. Replace it with the one you downloaded.
After that is done, check out your "General" settings and you will find a new entry, called "Touch"! Move the slider all the way over to the right and you will find that all of your icons are now workable!
This is not a perfect fix. You may find some element of erratic behavior here and there, and you might have to tweek the sensitivity of the Touch setting. You might also find that you have to touch a bit lower than the center of the icon in order for it to "take" your touch. Don't ask me why that is.
Hope this all helped!
Posted on Jun 21, 2008
    Problem Solver:
  • 5 Answers
Hi, I installed the touch fix above and it helped a little bit but later on things got worse and worse, phone crashing, speaker coming on when making call and the touch screen while better was still annoying. I figured out eventually that the whole problem was something to do with the earphone socket as it was worse when earphones were plugged in and so cleaned it out with a needle- finding all kinds of bits of fluff and lint had gathered in the socket- phone now working perfectly so maybe that will work for some of you too- no idea why but it did.
Posted on Aug 15, 2008
Hey guys i try to connect with winSCP my iphone 1.1.4 but it cant connect,what can i do??
Posted on Nov 01, 2008
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
How do i change the sensitivity on the behold 2 so that i can text with my nails?
Unfortunately this particular touch screen uses the heat sensitivity from your fingertips for the screen to work, like the iPhone or iTouch. A lot of the newer touch screen phones are like this now.
Apr 02, 2010 | Samsung Behold II SGH-t939 Smartphone
Hi, I have an Acer laptop with Vista OS. Like many others, I have a prolem with the curser, jumping all over the screen, causing a lot of typing mistakes/ problems. Is there aby fix for that?
I think what is happening is the heal of your palm is touching the touchpad. Try going in to the Control panel and lowering the sensitivity.
Jun 08, 2009 | Computers & Internet
Casio PX700 sensors not working
Hi. I don't have a 700, but on the other privia's I have seen, there is a function key combo to turn on and off the touch response. Go to casio, and download the manual. You hit "fn" and then one of the lower keys. There are 4 levels of sensitivity on my machine. -Don
Feb 05, 2009 | Casio Portable Keyboard Touch Sensitive...
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
My ds stylus screen wont worl!
Check all of the below:
Are you using the top screen? The lower screen is touch sensitive, not the top.
Do you have a protective covering on the screen? These sometimes interfere with the sensitivity of the touch screen.
Are you sure it's a ds? That picture is definitely NOT a ds.
Jan 05, 2009 | Nintendo DS Console
Portable DVD Player problem
The inter lock is sensitive add a little length to tab mine did the same
Aug 28, 2008 | Televison & Video
Left side of the screen not responding
  • Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
  • Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
  • If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
    1. Remove all games from the Nintendo DS.
    2. Turn the system on by pressing the POWER button.
    3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
    4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
    5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
    6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
      • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
      • If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
      • If the above steps did not help, there is a problem with the system and it will need to be repaired.
    7. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner.
    8. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
    Jul 14, 2008 | Nintendo DS Lite Console
    Iphones keypad
    The issue you are facing is known as a lower dead strip. You may eventually have to replace the digitizer but if you wnat to save some money then follow the steps below
    Downgrade to Firmware 1.1.4 (watch some videos on youtube)
    Jailbreak using idemocracy 3.0 (google it)
    Connect your phone and open fie browser for iphone.
    Move to /Application/Preferences.app/
    Replace the touch.plist and general.plist with the files found here:
    Restart your phone. Got to settings >>> general >>> Touch and decrease the sensitivity t0 -15.0
    Restart your phone.
    Should work fine now..
    Let me know.
    May 23, 2008 | Apple iPhone Smartphone
    Touch screen issues
    i recomend either a flip cover(if available) or a thick screen protector that lowers sensitivity.
    Feb 24, 2008 | Audiovox PPC 6700
    Apple iPhone Smartphone Logo
    5,631 people viewed this question
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    David
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
