Question about Arrow Heavy Duty Nail Master Electric Brad Nail Gun
Where can I purchase the nails for my gun? - Arrow Heavy Duty Nail Master Electric Brad Nail Gun
    Sergeant:
  • 200 Answers
Most hardware stores such as lowes,home depot,or potters.
Posted on Jul 20, 2010
My Hitachi nv65ah nail gun won't set nails into 3/4 trim. I have played with the turn/screw set adjustment and it is set for the deepest setting. This gun was purchased second hand off e-bay but
If every nail is stopping at the exact same height, a likely reason is the tip of the driver is broken off so it's not long enought to drive the nails all the way to flush. If the height of the nails is slightly different you may have worn or broken o-ring(s) inside the gun and air is leaking around the driver's piston or elsewhere in the gun so that the driver isn't getting full pressure. You can take the gun apart and inspect the o-rings. If you push the driver all the way down the tip should come flush or slightly past the end of the nose piece (not the safety tip). Parts are easy to find online or at a service center if you have one nearby.
Mar 10, 2012 | Hitachi NV65AH 212Inch Coil Siding Nailer
I have a N-60 finish nail gun. It is leaking from the trigger and it is trying to fire a nail and discharges the rod to drive the nails and the rod stops and will not retract. I think I need to purchase...
the trigger valve could be causing a lot of your problems, you are correct in ordering the o rings and trigger valve, make sure to lightly coat the o rings before installl. If you have trouble with the valve I have detailed instructions in the TIP section on how to remove safely.
Aug 15, 2011 | Stanley Bostitch Nail Gun
I have a 16 guage Bostich nail gun that has worked perfectly with the nails supplied with the gun. We purchased more Bostich nails and they are making a U-turn in the wood and coming back out. This is...
I would check first for the proper guage nails that you bought and then what is the capacity of the tool. You didn't specify the model number but I would think one or the other. then also check for the wood being nailed into. All could lead to your problem.
Feb 20, 2011 | Air Tools & Compressors
On the trigger of my Bostich Spiral load nail gun AND my Bostick trim nail gun air is leaking profusely from the trigger. Nail guns were not in use for about a year. When I first used them this weekend,...
A nail gun works on compressed air.
When you hook the air hose to the gun it fills a cylinder with air pressure.
When you pull the trigger. the cylinder pressure is released onto a firing pin that shoots the nail.
The air pressure line is also connected to the trigger and therefore the trigger has to be sealed.
When ever using a nail gun, you add a bit of gun oil in the back of the gun (not 3-in-1motor oil, it has to be non-detergent gun oil)
If you haven't used the gun in a while, it is best to oil up the gun and let the oil run down into the gun.
If you use anything but gun oil, the seals will give out.
Your trigger seal has given out. It is probably an 'O' ring. You can access it by taking it apart. Look for the O ring.
Bostich makes re-build kits for the different guns that you can buy on-line.
Back when I was in construction, there were several nail gun shops that sold and serviced nail guns, and sold nails to the contractors. I don't know if that business model is still active or if you have to send the guns to Bostich service center.
Oct 18, 2010 | Garden
I have a Item #9100 Powershot Pro Electric Staple & Nail Gun. I have lost my manual. Please tell me how to load staples.
I just purchase the powershot 9100 I can't get the trigger to work for the staples to come out. What am i not doing correctly?
Sep 18, 2010 | Powershot Tool Company Cobra 8000 Forward...
Wher can I purchase a replacement circut board for an Arrow ET200 Eletric Nail Gun. What I have is an ET200 - 110v Rev.2 I would like to purchase on line.
Do you still need this? I have a good board from my ET200. I dropped it, and the piece that keeps the nail driver steady when it shoots in & out broke off. However, the gun still functions fine. Let me know.
Oct 09, 2009 | Arrow ET200 Electric Brad Nail Gun
Will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
Jun 11, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
How to Install Air Compressor and Nail Gun
Set up the pressure on the air compressor. First plug the air compressor in, then check the pressure. It should be between 90 and 110 pounds per square inch (PSI) for home use. If it is not in this range, turn the knob to the left to decrease the pressure and to the right to increase the pressure. Use the appropriate nail gun for the job. For example, to nail shoe molding to base boards, a standard finishing nail gun would be perfect. It holds any size nail between 5/8 inch and 2 inches. This nail gun could be used for many projects with great results. Check the gauge the nail gun takes before purchasing the nails for the gun. If you get the wrong gauge they will not fit in the gun. You can check this by looking at the information printed on the side of the nail gun next to the model number. You can also open the nail chamber for this information. Attach the nail gun to the air compressor. You can do this before or after you load the nails into the gun. Use the air compressor hose to attach to the bottom of the nail gun. It screws on much like the end of a hose. If you do not have the right size air hose, you can find one at your local hardware store.
Aug 27, 2008 | Mountain Air Blow Gun with Rubber Tip
Arrow Heavy Duty Nail Master Electric Brad Nail Gun Logo
96 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
