Have a Panasonic DP2310 copier. It has a "E04-02" error code. What is it and what is the solution?
  • Michael Jenkins Jul 22, 2010
    I still need to know just what a "E04-02" code on a Panasonic Workio DP2310 copier is. I've tried *** the "easy" fixes but still have the code. If I knew what the code meant, I could finish troubleshooting. Help!
    Thanks! That is just the info that I needed.
  • 4,281 Answers
Make sure that you got ALL of the paper out of the fuser unit. Any code that is E4 you want to clean the fuser thoroughly otherwise when the machine goes to initialize it will not start paper lift motors. There is nothing wrong with the lift motors if the code is still E4. Make sure you take out the fuser unit and check all the sensors / clean them. Then just to be on the safe side I always do a LBP fuser reset. You need to go into maintenance mode and get to F9. Then from there go to Ram Initialize, then LBP Fuser Reset. The machine will automatically power down then start up. If it still kicks out the E4-02 at you after that I recommend replacing the photo interupter for the exit sensor. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 22, 2010
    Genius:
  • 1,040 Answers
On most copiers if you open the front door and close it, it takes care of most errors... (i.e. automatically it repairs most of the errors) While your doing that you might want to check for paper jams... otherwise get it serviced...
Thanks
Posted on Jul 20, 2010
  • Michael Jenkins Jul 21, 2010
    Have tried all the normal fixes. No paper jams. All doors closed properly. Have cold started the unit again. Still have a "E04-02" code. If I knew what that referred to, I'd know where to go and how to fix.
What does J40 code indicate?
Error Codes Panasonic Copiers
errorcodepanasonic.blogspot.com/.../error-codes-for-panasonic-copiers.h...Jul 17, 2011 - Error Codes for Panasonic Copiers problems solusions help ... J40-42, Fuser exit jam ... dp 8060 code e-501 plz tell the solution what can i do ... I need a help with my Panasonic DP8045 printer. ... DP 6010 DP 6020 G DP 6020 H DP 6030 DP 6030 G DP 6030 H DP 6530 DP 7000 DP 7240 DP 8016 P DP ...
2015/16 ICD-10-CM Diagnosis Codes J40.* : Bronchitis, not ...
www.icd10data.com/ICD10CM/Codes/J00-J99/J40-J47/J40-
Home > 2015/16 ICD-10-CM Diagnosis Codes > Disability of the respiratory system J00-J99 > Chronic ... Bronchitis, not specified as acute or chronic J40-
Nov 06, 2015 | Office Equipment & Supplies
Error code 410 in panasonic copier DP4510
just press on this link and there is multi solution for the code error okay man===> http://www.manualslib.com/manual/360974/Panasonic-Workio-Dp-2310.html?page=209
Feb 06, 2013 | Panasonic DP4510 Workio Upper Fuser Picker...
Printer showing error message ...."printing
This means that your machine has received a print job that is teling it to print on paper that is loaded or supposed to be loaded in the bypass feed tray. You will either need to delete the print job using the operation panel or simple load some letter size paper in the bypass tray over on the right side of the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Panasonic Workio DP-3030 Printer
Panasonic DP3510 copier error code
This error is for the copy density sensor. Remove drum unit, 1 screw, and you will see the sensor inside of the machine. Either dropping toner out of the drum unit or machine is overtoned. I would recommend a service call from a technician for this problem.
Jul 29, 2009 | Panasonic Office Equipment & Supplies
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
Dp2310 panasonic
Do you want the cheap way or the right way? Try the cheap way first try to change the papers postion in the paper tray.. If it is running LTR change it to LTR-R. If that fix's it your in luck for now, but it will need to be adressed sooner or later.
May 21, 2008 | Office Equipment & Supplies
Panasonic 7735
Hi Yes can help but need to know the code. If you open and close front cover machine should reset.If not need the code
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
88 people viewed this question
jasbo
jasbo
