Question about Zanussi 24 in. DE6850 Free-standing Dishwasher
Zanussi DE6850 doesn't start. switches on and then not a sound?
I have a Zanussi DE6850 dishwasher. It was working fine until recently. Yesterday I tried to use it again and it doesnt start.
It just swithes on and thats it. Not a sound. We've tried tiling on side to remove water. Is there anything we can do to fix this?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to check the following things--
1. Fuse (blown or tripped).
2. Check the wire fasteners at dishwasher junction box.
3. Electronic control board.
4. Motor (inoperative, check resistances).
5. Door switch (open contacts).
6. Door latch not making contact with door switch.
7. Touch pad circuit defective.
8. No indicator lamps illuminate when START or OPTIONS is depressed.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 20, 2010
Where is the heating element on a zanussi de6850 dishwasher
remove RHS panel and you will see it bottom right. looks like a round cylinder with wires going into it.
if not heating worth looking at main board as wel for a broken solder joint on heater relay. bit of solder will sort this
Oct 19, 2010 | Zanussi 24 in. DE6850 Free-standing...
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
F70 fault error keeps appearing on my Miele G1220SC full dishwasher - any idea?
it is the float switch in the base of the unit, which registers a water leak. you are probably using too much detergent and it is overflowing into the base.
Oct 31, 2009 | Zanussi 24 in. DE6850 Free-standing...
Water not getting hot
Start checking the element. (assuming you have a tester).If reading is good,(approx. 20-40 ohms).then check for a reset switch. Normall a red push to resed button or if there is continuity.. From there it can only be the board which outputs the heater voltage.
Sep 19, 2009 | Zanussi 24 in. DE6850 Free-standing...
ZANUSSI DE6855 DISHWASHER - NO HEAT FOR WASHING OR DRYING
Make sure you unplug before you start. I had the same problem with a DE6850. The heater was ok. Metered at 25.ohms. Apparently, the relay on the control board mounted in the front door behind the switches is a common fault. Remove the screws around the top part of the door and you will be able to get at the control module. Resolder the connection. Zanussi reliability has been lost. Noel P31bf5e2.jpg
Apr 12, 2009 | Zanussi 24 in. DE6850 Free-standing...
Zanussi Dishwasher DE6850
Sounds like a heater problem to me, does it go through the complete cycle on its own?
Dec 02, 2007 | Dishwashers
Dishwasher was tipped and won't run
I have the same problem if you take off the tray below the front door and set a small blow heater in there it will dry the out the anti flood switch. It usally takes about 25 mins for the machine to start working again.
Feb 21, 2007 | Zanussi 24 in. DE6850 Free-standing...
Zanussi 24 in. DE6850 Free-standing Dishwasher Logo
107 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
