Question about Electrolux EOD6330 Ultrafan Electric Double Oven
The door of my electrolux EOEE63AS does not close properly. I think the door or hinges needs some adjustment. How do I go about that? i.e which screws do I need to adjust? thanks in advance. dat.
5 Suggested Answers
  • 1314 Answers
SOURCE: Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Posted on Dec 29, 2007
kachbibi1
  • 979 Answers
SOURCE: i need a bottom door for an electrolux edb876 double gas oven
You will have to get a replacement from the mfr. It is not very difficult to replace, but can be time consuming. First before you buy one, make sure the hinge is broken and not just loose from the frame.
Posted on Feb 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Westinghouse oven does not close fully.can door
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Posted on Nov 08, 2009
Testimonial: "Thanks for your help.will try that."
barkencoa
  • 3463 Answers
SOURCE: Main oven door not sealing. How do you adjust the
If it has a drop down door, then no adjustment is possible, the only solution is to replace both hinges.
Thanks.
Posted on Nov 11, 2009
Testimonial: "Thank you for your quick response - it did not look like any adjustment was possible but the oven is only 18 months old with little use. Thanks again"
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Our ELECTROLUX EOEE63AS oven door will not shut properly have got nowhere with ELECTROLUX SERVICE HERE IN South Australia, any clues!! Mal
Don't waste time with a new door like I did. The door hinge is poor design in my opinion. Buy 2 super magnets on eBay, there's a seller a Flinders Park in S.A. The magnets should be 24mm x 9mm x 3mm thick. Place them top left and right of the open door outside the seal on the stainless panel. See pic.
Problem solved.
Feb 15, 2013 | Ovens
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Oven door won't stay tightly shut
Oven door hinges are not adjustable, assuming you have fitted the door back correctly, and it is still not closing properly, then the only solution is to replace the door hinges.
Jan 20, 2010 | Whirlpool RBS275PD Electric Single Oven
The door of the main oven does not close properly even though we replaced the hinges (which worked initially) only about 18months ago. It's a U1420 NOGB double oven
If ther is notjhing obstructing the door from closing poroperly, then it sounds to me like the hinges are the cause of the problem again.
Make sure there is nothing trapped at the bottrom of the door, and that the hinge/s are not loose.
If it is leaving a small gap at the top of the door, then I think your only option is to replace the hinges again, as there is no adjustment possible of the hinges.
Hope this assists you with your problem
Dec 03, 2009 | Neff Ovens
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Electrolux EOD6330 Ultrafan Electric Double Oven Logo
212 people viewed this question
Top Electrolux Ovens Experts
Steve Allison
Steve Allison
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
