I have a Kenmore HE 31 Front Load washer. When I turn it on, select the cycle and hit start, nothing happens. Ive tried holding down the start button. any suggestions?
  • Bucc Jul 21, 2010
    Thank you very much!
    President:
  • 1,554 Answers
There are only two possibilities that may cause the washer not to start. First is the failure of the door switch to activate but it should flash a fault code and second is the failure of the control panel particularly the Start button. The Start button is stuck if it just flashes when pushed to start the machine or not activating at all if the machine does not respond at all when pressed.
Check the Start button and make sure it is not stuck and it should make contact when pressed. Replace the touch pad/LED assembly if the issue is not addressed. Disconnect power to the washer prior to servicing to avoid the risk of electric shock that may result in physical injury or even death.
Remove the screws attaching the top panel to the rear of the machine then slide it rearwards and off the cabinet. Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening then release the tab securing the right side of the console to the washer. Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console then push the console up to release center console tab and remove the console.
Remove the cycle selector knob then release the tabs securing the Touch Pad/LED Assembly to the console. Release these tabs in sequence from left to right around the Touch Pad/LED Assembly until all of the tabs are free and the assembly can be lifted from the console.
Unstuck the Start button or clean its contacts if necessary then take the opportunity to inspect the other keys for any possible short circuit.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You can continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 20, 2010
Nothing happens when the 'Start Button' is pressed on Electrolux Front load washer
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
May 20, 2015 | Electrolux IQ-Touch Series EIFLS60LT 27"...
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
Kenmore elite 45986
Make sure you have the knob on a cycle selection. Sometimes while loading, you may hit the knob and get it just in between a selection and might not start. If that isn't it, I would say you need to replace your start button. Take the control panel off and if you have a volt meter, test to see if there is a current.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front load washer
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer - "Control Locked"
Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Dec 29, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Kenmore HE front load washer
seems to be a fault design in the doorlocks, fit new lock
Nov 16, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
