Whenever I print e-mails the printout is cut off at the left edge of the paper. The margin appears to be about 5/16 from the left edge of the paper and the 1st couple of characters in each line do not print. I have tried different printers with the same result. (HP DeskJet 1120C and a Sharp AL-1451 Laser copier/printer. I have tried to change the margins on my printer through Microsoft Word but it did not help. If I save the file to a Word processor, the print is normal and everything is ok. This problem just happened within the past month. Prior to that everything was fine.
-   henever I print e-mails the printout is cut off at the left edge of the paper. The margin appears to be about 5/16 from the left edge of the paper and the 1st couple of characters in each line do not print. I have tried different printers with the same result.
-   macbhai
Printing for Outlook Express is set in Internet Explorer. Open
Internet Explorer and go to File, Page Setup. Change the left and
right margins to .25 inches or more.
spooling random documents every 2 minutes which have not been selected to print, which jams the...
(More)
spooling random documents every 2 minutes which have not been selected to print, which jams the print queue and leaves it with 1000s of unprinted items .
it just sits and stutters at start up for a few minuets and stops.The copy table hi-intesity lite is...
(More)
it just sits and stutters at start up for a few minuets and stops.The copy table hi-intesity lite is on while it does this.
sabe como fazer para pdesbloquear a sharp al 1000 ,fica piscando luz do drum , e ja troque o...
(More)
sabe como fazer para pdesbloquear a sharp al 1000 ,fica piscando luz do drum , e ja troque o cilindro ,o p?, e o revelador. e cotinua piscando. que devo fazer.?
Hello Chris...! please could you sendme that driver, for my sharp al 1451 Tnks...
(More)
Hello Chris...! please could you sendme that driver, for my sharp al 1451 Tnks franklin_tapia@hotmail.com
