Question about Sony Televison & Video
Connecting sony dvd home theatre with led tv - Sony Televison & Video
  • 177 Answers
If your Dvd player has HDMI out, then use this to take the picture to the TV. If it only has scart, then use this. Use a fibre-optic TOSlink cable to connect the audio from the TV to the Home Theater. If the home theater doesn't have Optical in, then use red and black phono(rca) cable.
Posted on Jul 20, 2010
Have Viano 40inch LED LCD TV and Sony Blu-ray home theatre. Need help to input code number to use Sony remote. Thanks.
Hi . I would look at your Sony instructions and the part where it says about putting in the codes . You should see your TV model listed .
Apr 05, 2015 | Sony Televison & Video
How do I attach sony w60b to sonny DAV-HDZ 284 DVD Home Theatre System?
You can use the Component Video, composite video or HDMI connections to connect the DVD home theatre system to the TV.
See the manuals on this site.
DVD Home Theater System
Sep 15, 2014 | Sony BRAVIA Televison & Video
Sony tv not syncing to dvd home theater
You need to check the connections between the tv and the home theatre audio array.
Did it work previously?
Heres the manual..go to page 29 and 34 to make sure it has been installed and connected correctly.
http://download.sony-asia.com/consumer/IM/4165486121.pdf
Mar 09, 2014 | Sony Televison & Video
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
Televison & Video Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
