Question about Pioneer DVR-220 DVD Recorder
Can irecord on my dvr 220 pioneer from my new freeview tv
  • 177 Answers
Yes you can do this. You just need to make sure that the TV outputs its picture on the scart lead that you have connected to the Pioneer unit, and you need to set the Pioneer unit to record from that scart input. Once this is done, it will be able to record whatever you have on the screen. Be aware though, if you turn off the TV it stops outputting its picture to the recorder, and if you change channel, it changes what what the recorder see's too. I hope this helps you. :)
Posted on Jul 20, 2010
HOW TO CHANGE THE REGION CODE ON A DVR-220
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Region code hacks and codes to many popular devices are given.
May 01, 2015 | Pioneer DVR-220 DVD Recorder
Does the pioneer dvr-720H-s connect to digitial tv?
The pioneer dvr-720H-S doesn't have a digital tuner. It has a PAL and a SECAM tuner (the European version). You'll need a digital to analog converter or a cable/satellite receiver to provide a signal for the unit to record the digital channels.
The specification list for the DVR-702H-S is available here: http://www.pioneer.eu/eur/products/archive/DVR-720H-S/index.html .
I wish that I had better news for you. Note: the most common D-T-A converters have SD output.
(I know in the UK the digital format is DVB-T2 for FreeView)
Jul 22, 2012 | Televison & Video
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
I own a Pioneer DVR-220 dvd recorder and my problem is that the unit will not power up. I've tried disconnecting the ac power cord from the Monster Power power source and connecting the power cord via an...
I replaced two capacitors, (1) 10 volt, 1000uf and 10 volt 3300uf..They both sit on the power board that can be removed from the unit..You will have to unsolder the bad capacitors and put in the replacements..This wasn't hard to do...
Jun 26, 2010 | Pioneer DVR-220 DVD Recorder
Pioneer DVR-220 will not power up. Any suggestions.
First check the in line fuse...it sits right behind the electric plug on the chase..You have to remove the screws to open the case to check this....If the fuse is okay, you will have to replace these two capacitors, 10 volt, 3300uf, and 10 volt 1000uf...they are located on the same board that houses the fuse...the two location are c23 and c19 on the power board...
Jul 08, 2010 | Pioneer DVR-220 DVD Recorder
What plugs in where at the back of model 32AV633D Does single scart go to ext 1 or ext 2 Where does outside aerial plug in, there are so many ? Sorry but I'm a complete technophobe who is hopeless at...
If you have a cable box or freeview box, your main aerial lead plugs into the box. Then you connect a scart lead from your cable box/freeview box/ or dvr box to ext 1 on the tv. Where the aerial lead plugs into your cable/freeview/dvr box, there may be an aerial out socket too. You could connect a patch lead from the box to your tv as well so you have UHF direcy from your cable/freeview/dvr box to the TV as well as scart
Aug 06, 2009 | Televison & Video
Open Questions:
Pioneer DVR-220 DVD Recorder Logo
103 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
