Question about Coleman Camping, Backpacking & Hiking
Coleman rechargeable lantern: Charged overnight - not working, replaced bulbs - not working. What could it be:
  • Anonymous Mar 14, 2014
    What do I have to do to get a good working light
  • 283 Answers
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
Posted on Jul 21, 2010
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
I have a coleman 5317 RC series lantern that wont go into the dim mode what can I do
Hello. I've just looked at several Coleman lamps, some have krypton bulbs (mainly battery powered), some spiral fluorescent bulbs (mainly mains powered/charged). If this one is yours http://www.coleman.com/Parts/100/parts-lanterns/5317-702/remote-control-pack-away-family-size-lantern# then it appears yours has a spiral fluorescent bulb. Gas discharge bulbs commonly are fired up by an initial high voltage pulse then followed by a continuous ac medium voltage (say 80 volts or so) to give a FIXED LIGHT OUTPUT.
THIS DOES NOT ALLOW CONTROLLED DIMMING. Dimming can usually only be done on an INCANDESCENT TYPE bulb eg an older type tungsten filament bulb. These are however much less efficient.
So in summary, if you do have a fluorescent bulb, I don't know why your remote indicates you can dim it. You could try switching the bulb for an incandescent type, but this should only be attempted by qualified persons. Check over the user manual again. Good Luck.
Jun 17, 2014 | Coleman 5317-700 lantern - 8d square...
Does not switch on after fully charging night light works if charger is plugged into power point
will the main light come on when plugged in? it might just need a new bulb. if so it might be a dead battery
Mar 11, 2014 | Coleman Retro Rechargeable Battery Powered...
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Tried to charge my Coleman Retro Lantern, the red light for charging is on but after 24hrs charging, I take the charger off and try to turn the lantern on, it wont work. How can I fix this...
I just bought a retro rechargeable sealed battery,recently. I charged it for 18 hours,the lights all worked,but I don't remember the green light comming on.i put the lantern away for 3 months or so.i decided to check the the battery light out first week of june, the light was there,then I said let me charge it up again, I never seen any green light come on showing it was fully charged. I took the battery out and checked the wires to see if there was a break. None that I could tell. After you take the battery out ,there is another section square that covers where the bulb is located,but I didn't touch that part yet. Stuck" on this one. Help"
Sep 15, 2011 | Coleman Retro Rechargeable Battery Powered...
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Cant figure out how to take apart to replace bulb
More information is required in order to answer your question. However, the following link will take you to the Coleman website for battery powered lanterns. www.coleman.com/coleman/parts/product_category2.asp?category_id=170
Jul 19, 2010 | Coleman Rugged Battery Powered Lantern...
How do you relamp the GE model 17000 lantern
Visit the Coleman site to locate your particular lantern.
http://tinyurl.com/2a9j2xx
Jul 02, 2010 | Coleman Retro Rechargeable Battery Powered...
Camping, Backpacking & Hiking Logo
2,403 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
yobo007
yobo007
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
