Question about Xtreme N Dual Band Usb Adapter (dwa-160) - D-LINK - DWA-160 Pre-802.11n
DLink Dual Band USB Adapter will not connect to internet
I have a D-Link Dual Band USB Adapter. I am trying to connect to a wireless network on my desk top. The settings work fine on our laptops. The DLink finds the connections but will not connect to the network. I am using Windows 7. When I called D-Link they said as far as they were concerned all was fine and I should contact HP (the computer people)
My cisco linksys ae1000 adapter does not have internet connection
If haven't yet check Device Manager, go to Network Adapters and look for Linksys Wireless Adapter. Check the status of the adapt
Also look for errors codes on anything. Make sure all is enabled or need to install drivers.
If all fails remove adaptor and all drivers for it, restart computer and reinstall adaptor.
Aug 04, 2014 | Cisco Linksys AE1000 Wireless-N USB...
Older XBox 360 with wireless antenna - can't connect to network - why not?
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Jan 12, 2013 | Video Game Consoles & Games
I have configured my DLink dual band router as well as my usb adapter. On my connection manager it says it is at 100 %, but my internet access is not avaialable. I have a yellow house and am not able to...
IF it says you are connected wireless, you are connected the DLink router. But the DLink router is not configured properly. If you connect your pc directly to the modem and goes online then that is a proof that the DLink is not properly setup. There is a possible IP conflict between the modem and router. I suggest you change the IP address of the router to 10.10.10.1 .
Apr 05, 2011 | Computers & Internet
Linksys Wireless Adapter that will not find the internet
I think you might be using the Linksys utility.
you can switch over to windows utility if it is XP or VISTA.
that will resolve the problem.
make sure that it will be connected to the network and should have proper IP address
Click Here for more info about wireless network set up
Oct 12, 2009 | Linksys Ultra RangePlus Dual-Band...
I have broadband cable service. My cable modem ic connected to a Linksys Dual band wireless router. My computer is then connected to the wireless router on USB port 2. My Link sys VOIP is connected to the...
First unplug your router, then unplug your modem and for 10 seconds. Next plug the modem back in and wait it to reboot(on mine this a series of 4 lights that light up in sequence, when the 4th light stops flashing, reboot is complete). Finally plug your router back in.
Sep 09, 2009 | Linksys Ultra RangePlus Dual-Band...
Linksys dual-band wireless-n gaming adapter + westell versalink
put all the adresses and getways(on xbox internet setings same as pc then it should work
Mar 25, 2009 | Linksys Dual-Band Wireless-N Gaming...
Xtreme N Dual Band Usb Adapter (dwa-160) - D-LINK - DWA-160 Pre-802.11n Logo
Top Xtreme Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Xtreme Computer and Internet Expert? Answer questions, earn points and help others
