Question about Exercise & Fitness
I have a Weslo 865 Treadmill and am getting an E2 error on the Speed display; treadmill will not work
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: I have a Weslo 865
hi,
ur treadmills motor controlling circuit have some problem. that's why it shows e2 or the speed sensor may be oppen . as these potion of ur treadmill is a high voltage point, i will recommend u to consult the manufacturer for support. if u can do it yourself the go for it
ok
Posted on Jan 06, 2011
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
it's normal operation.
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
hi,
ok
Jan 06, 2011 | Cadence Exercise & Fitness
The meter that you set that tells you your speed, distance and calories burned stays at 0:0...the mode moves around when you push that but it stays registered at 0 for all modes. I put new batteries in it...
hi,
check ur tread mill's control consoles press button switches first. if all good the other chance is, ur control console have a programmed ic (integated circuit) in it. some programs are loaded in that ic, with which its displays speed distance traveled and all other settings. may be posibiliy for the ic get faulty. if so, the any way is consult the manufacturer, because you will not get the same in open market.
ok
Dec 27, 2010 | Treadmill Doctor Weslo Cadence Ex16...
Our Weslo Cadence Dx12 treadmill will only operate at the highest speed and will not turn off without the safety key. The speed cannot be adjusted to slower speeds.
Go to Radio Shack and buy some contact cleaner. Clean the peed control on the console. If that doesn't solve the problem, you will need to replace the motor controller PCB..
Dec 11, 2010 | Treadmill Doctor Weslo Cadence Dx12...
E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Jun 26, 2010 | York Barbell Home Use Fold-Up Treadmill
I have a weslo cadence 200 cs treadmill. I changed the batteries but the display keeps blinking 0
You probably need a new treadmill display screen but one thing you can try is to get a 6 volt power suppply and use the power supply instead of the batteries.
May 20, 2010 | Exercise & Fitness
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Exercise & Fitness Logo
81 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
