Question about Splendide 2100XC
Door lock not engaging on our spledide XC 2100
The door lock not engaging and therefore the machine will not operate?
I'm Sorry to post a complete "Gerry Rig" solution to the problem: I inserted a plastic clip in the door lock to fool the machine that the door was locked; removed the clip then secured the door with a tension rod. It ran its full cycle without a leak. I think the plastic door mechanics was inadequately engineered. Our Machine is less than 6 months old?- Im on the road & have to make things work on the fly. Warning my next fix might include Duct Tape Good Luck Everyone Kevin_ByDesign
Posted on May 04, 2011
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Handle broke off
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
Opening a locked washing machine door - YouTube
? 1:30
https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
How to open a broken washing machine door. - YouTube
? 0:25
https://www.youtube.com/watch?v=UCJPkc_dTCE
Feb 26, 2013 - Uploaded by Kim Degerth
How to open a broken washing machine door. .... How awashing machine door lock works, how to test ...
How to Fix Washer With A Lid Or Door That Won't Op
Oct 07, 2015 | Splendide 2100 Vented Washer-Dryer
Remove 'spledid demo'
Down load a program called "perfect uninstaller" Also "spyhunter 4" run one after the other removing all reference to Splendid.
Jan 01, 2014 | Computers & Internet
Lights come on to operate except door light,the door is locked but no a action on hotpoint wf430
Worn motor brushes can cause this. The door lock is on the same circuit as the motor so if brushes are worn it doesnt know door is locked and therefore wont start. likely just needs new brushes.
Oct 30, 2013 | Washing Machines
My Zanussi jetsystem1400 xc didnt finish its cycle. ERR came up. After switching it off the door would open letting the water out. I have since cleaned the drain motor filter removing a plastic stick...
Your symptom suggests there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 09, 2011 | Washing Machines
Will not spin
You have 1 of 2 problems, the 1st being the door lock mechanism is not engaging, therefore as a safety feature it will not spin. The 2nd is that the drain pump is clogged or broken. Very easy to unclog, a little pricey to replace.
Dec 01, 2010 | Kenmore Front Load Washer
Washer will not completely spin dry . clothes left lying in water. We have checked the water supply hose screen and it is not plugged.
Your door lock switch (not the one that turns your "door locked" light on) which allows your spin cycle to engage is probably not engaging properly. This is usually caused by the failure of the motor which locks the front washer door, and not this switch. As you know, that door is difficult to open even when it is unlocked so there is really no need for it to be locked.
Therefore, instead of spending a pile of money tryng to resolve this problem, make sure it does not happen again by tricking the machine into thinking the door is locked.
To do this first remove the front washer panel. Then remove the front screws which lock down the top cover. This gives you access to this switch. Fold up a piece of stiff paper and jam it in next to this switch so that it alwatys gives a "door is locked" signal to the machine control board.
Your machine should now operate and spin properly.
Of course the washer door will always be unlocked while the washer is operating but my door has never flopped open after making this repair. It certainly beats paying $200 for a replacement control board, and even more if something is also wrong with the locking motor. Remember that any replacement board will be just as junky and defective as the original board was.
Always remember, when you get ready to buy a new washer, not to buy any front loaders, because they are all poorly designed and therefore, because of the cheap materials used overseas in making them, they all rapidly become mechanically defective.
Good luck.
Jun 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Splendide 2100XC Logo
268 people viewed this question
Top Splendide Washing Machines Experts
Philip Diggins
Level 1 Expert
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
