Sony Playstation 3 (PS3) Console Logo
Posted on Apr 22, 2008
Playstation 3 Internet is not working for my playstation 3 it works on the computer though, it can't obtain the IP address
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
90
Points
U should check your connection or get a better wireless router if you dont have one. i suggest a netgear.
My playstation won't connect to the wireless connection even though the internet is fine as both laptops in the house work fine. I have tried testing it and the test fails at obtaining the IP address, I've...
sometimes the router can be set to high on the wireless security side of things for example WPASK wich is 256mb encription wireless aand some adapters do though you out!
Cant obtain an ip address
try using a modem, connecting a ethernet cable to your ps3 and computer, then your internet cable to your computer and modem. it should work after that.
2helpful
Trouble obtaining ip address
When you put the IP address in you also have to add your DNS settings. easiest way to find your DNS server address is to use an XP based machine and type "ipconfig /all" it will list all of the properties of your computers network card. thake those DNS address' and plug them into your PS3.
1helpful
Router works but internet to computer does not.
Your pc might be using a static IP address. Make sure its on automatic. Go to Control Panel, Network Connections. Right-click on Local Area Connection and click Properties. Look for Internet Protocol TCP/IP and double click it. Select Obtain an IP Address Automatically and Obtain DNS Servers Automatically. Click OK all the way out. Also disable any firewall you have like Norton Firewall, McAffe, Zone Alarm and the likes.
PS3 will not obtain IP address
Perhaps resetting the router will solve your problem. Have you tried that?
1helpful
PS3 (80GB) Obtain IP Address : Failed, Help?
Try swapping the ends of the ethernet cable between your PS3 and the router. Otherwise, try a different ethernet cable. Also check that there are lights on by your ethernet port on the PS3 and the router.
1helpful
3answers
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
2answers
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
