Question about Celestron NexStar 80GTL (180 x 80mm) Telescope
Motor blewn up
I changed the power source and it blew up the motor,I could smell smoke from either the tripod and the hand control. Now when turned on, the motor keeps moving and can't be controlled.
Is there anyway to replace the circuit board only and where can I buy it?
  • 3,186 Answers
Contact Meade Customer Service here:
http://www.meade.com/support/index.html
Posted on Jul 22, 2010
My 94 Ford Taurus isn't blowing cold or hot air when it went like that it blew smoke from the vents and it smelled like burnt plastic
Faulty blower motor, or relay, possibly bad blower motor or resistor. Can possibly be bad blower motor switch.
Dec 15, 2013 | Cars & Trucks
My 94 Ford Taurus doesn't blow cold or hot air it was working fine till all of a sudden it just smelled burnt and blew a lil smoke ???
The blower motor probably failed. Buy a used one from salvage. Test with jumper wires before installing. Usually, the blower fan motor is easy to change-easily accessed. Disconnect negative battery post, then the blower motor connector, remove 3 or 4 screws to pull motor and fan assembly out.
Smoke coming through vents temp. gauge going up acting like its going 2 overheat turn heater on hot and smokes bad turn to cool and smokes a little my husband thinks it's the thermostat and wants to...
If the heater core is leaking, you would get a lot of steam that would smell "sweet". That would also leave you low on coolant, which could be a source of your overheating. If it's more of an electrical smell, you may have a blower motor or a blower motor resistor going bad, but won't cause the engine to overheat.
May 03, 2011 | Ford Ranger Cars & Trucks
Will drain most of water but will not spin and smell something burning
The motor is probably stuck and burned. Open the door and turn the drum manually. You should be able to turn it easily by hand if the motor is not stuck.
Remove the back panel and use your sense of smell to verify where the burning smell is coming from. The possible source of the smell is the motor or the motor control board located on the left side of the machine viewed from the rear.
Let us know the source of the smell for the replacement guide and for further troubleshooting if necessary.
Feb 22, 2010 | Washing Machines
Wiper blade motor smoking
If it's damp and cold and the motor is smoking a bit it may just be wet (if it is working well otherwise) If it's dry and smoke is coming out of it, there is a short inside and it needs to be changed. In either case, if the smoke smells electrical (steam does not smell) change it as soon as you can because the additional amperage needed to run it will also damage control components upstream of the motor.
Feb 09, 2010 | 2006 Jeep Grand Cherokee
18v dewalt battery gives off burning smell
18v is one of the newer models, correct? And the drill is new? If so there will be some smell as the motor breaks in. The srmsture is varnished as well as the windind for the commutator. The first few times it get s warm/warm from a heavy load, You will smell it. I would say there is nothing wrong at this point.Do not overload the motor and avoid drilling at low speeds. Use the variable trigger at low speed only for starting a hole. If you are driving screws start the screw,then full trigger driving it in. Good Luck, Ned
Nov 06, 2009 | Drills
A/C smelled like smoke then blew 30A fuse - Silverado 1500 2004
You may want to change the blower motor as a precaution.
Do all the fan speeds work?
If not .....change the fan resistor board which is right beside the fan at the same time you change the blower fan motor.
Aug 26, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Installed new machine control and blew R-11 again
motor coils must have been shorted..test resistance of motor terminals..
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Jan 26, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Celestron NexStar 80GTL (180 x 80mm) Telescope Logo
59 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
