Question about Casablanca Fan (3232A) Ceiling
Intell-Touch instructions for casablanca fan/light
How do I operate the Intell-touch controls on my casablanca ceiling fan and light?
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Posted on Aug 05, 2010
  • marlenefw Sep 05, 2011
    My fan will not do multiple speeds any more, since the power came back on. It just blows at high. If I hold the button, it stays off and makes a wimpy beep, but no speed control. Any suggestions?
  • inventorr Sep 05, 2011
    Those Intelli-Touch light and fan speed controls are sensitive to voltage fluctuations and power outages. Does the variable lamp dimmer still work? You might try to turn off the power breaker that controls that switch for a few seconds. If you are lucky, this might unlock the logic (though simple) inside the switch. Good luck.
How can I change from a remote control system ( which rarely works) to a wall control switch for my isotope 44 from casablanca
Casablanca may be able to supply instructions for alternate methods of wiring your fan for direct control vs. remote control.
Jul 28, 2014 | Casablanca Fans 44" Casablanca Isotope...
Fan working but light won't turn off from remote
Call Casablanca @ 1-800-715-0393. It could be a bad light kit ( which can be replaced) or bad receiver.
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
My inteli-touch casablanca fan won't turn on at all (light or fan). Today there was an interruption of electrical power to the house and now the fan won't work. I know there is a way to "reset"...
I have had 3 casablanca intellitouch fans stop working. All 3 had the same problem. The 1000uf/35vdc capacitor failed. Replaced with 1000uf/50VDC cap from Radio Shack. No problems since.
Nov 09, 2010 | Casablanca Fan 3245T Ceiling
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
I have a Casablanca Intelli touch ceiling fan. The remote is a simple toggle switch, turn in on, listen to the beeps, off an on quickly to set it. How do I reverse direction on this fan?
My fan operates the same way. To reverse it, turn it on a low speed. Then, turn it off and on, then off and on again, quickly. You should hear a series of beeps, and the blades will slow down and then reverse. You may have to play a bit with the timing of the off/on/off/on sequence to get it right but you should be able to get it fairly easily.
Apr 01, 2010 | Casablanca Fan 3245T Ceiling
I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
Casablanca ceiling fan lights flicker out
here is solution for you.
instead of put all Fluorescent light bulb, put one incandescent bulb.
Dont' ask why but it works. (use 60w or above)
Mar 15, 2009 | Dryers
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Casablanca Fan (3232A) Ceiling Logo
1,171 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
