Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Refrigerator temperature is 30. We cannot set it
Refrigerator temperature is 30. We cannot set it to 37.
    Top Expert:
  • GE Master
  • 12,744 Answers
Check the fan that runs between the freezer and fridge in the fan housing is a damper that opens and closes if ice or debris is blocking or in way clear so damper can open and close the fridge is cooled by the freezer
Posted on Jul 20, 2010
User manuals
google user guide sanyo model sr-290 also the temp setting for 37 deg is 37 deg the numbers on the dial are only for reference you should get a thermometer for accuracy
Dec 01, 2013 | Sanyo SR-290 Compact Refrigerator
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
Step 2
Step 3
Step 4
Step 5
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
The refrrigerator and freezer not holding tempreture it started with the freezer - how can i fix - i have defrosted the freezer and removed all food?
hi there,
have you check the temperature?
The temperature controls are preset in the factory at 37°F for the refrigerator compartment and 0°F for the freezer compartment. Allow 24 hours for the temperature to stabilize to the preset recommended
settings.
The temperature controls can display both the SET temperature
as well as the actual temperature in the refrigerator and freezer.
The actual temperature may vary slightly from the SET temperature based on usage and operating environment.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
Jun 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is not cold
hi,
settings.
Refrigerator side not cooling but freezer works
hi there,
first check is anything is blocking the refrigerator door from being closed properly.
Then see if the temperature is set correctly.
settings.
Jun 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How can lower my refrigerator temperature to 37?
You need to unplug your unit for 24hrs. You need to clean out the fins with air compressor and vacuum. This has worked wonders for my 550.
Jan 04, 2010 | Sub-Zero Bottom Freezer Refrigerator
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
Refrigerators Logo
209 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
