Question about HP (DW017A) Ultrium Tape Drive
Why are the blinking of cleaning lights of tape drive HP Ultrium 448 Model No. DW017B
  • 154 Answers
Use Library and Tape Tools (L&TT) to upgrade to the latest firmware
This is especially important if the problem with an Ultrium 215 or Ultrium 230 (LTO Generation 1). Outdated firmware in these models can often give load problems.
New revisions of firmware are released to fix issues that have been found since product launch. Some of these are firmware defects and some are additional functionality to deal with new drivers, server or application behavior etc. It is always recommended to ensure your drive has the latest released firmware from HP.
All firmware releases are tested thoroughly by HP and drives will only accept firmware that is intended for them - they will reject the wrong version - so don't worry, this is not a risky process.
Whenever you perform a firmware upgrade make absolutely sure that the upgrade process is complete before power-cycling the drive. If the drive is power-cycled while the upgrade process is still in operation the firmware could be corrupted resulting in a dead drive.
Ensure you have the most up-to-date drivers for your device.
If you do not already have L&TT click here to download
Click here for the L&TT FAQ. (www.hp.com/support/lttfaq) Look for How do I verify that my drive's firmware is up to date? in the contents.
Posted on Aug 12, 2010
I can backup small files but there is a problem with big files and folder ..message error
Try placing the larger files and folders in the zip part of the system and there should be no more problem
Oct 07, 2013 | HP Ultrium 448 (DW016A) Ultrium Tape Drive
Hp storageworks ultrium 448 drive light blinks orange
Hi John, not sure from your description which light you refer to.
But this sounds like your drive has either had a read / write issue - in which case you need to run a new cleaning tape through the unit and then retry using a brand new data tape - OR it has had a damaged tape loaded into it which has now broken the tape drive.
If the drive has been broken then try contacting www.tape-drive-repair.com who can repair or replace it for you and also look at
http://tape-drive-repair.com/tools-and-information/lto-media-inspection-guide/
The guide will tell you how to inspect ypoour media for damage and prevent you from reloading a damaged tape which will break your drive again
Sep 12, 2012 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Win server not compressing hp ultrium tape drive
you never actually asked question.
is this a tape space issue, (compression not up to par)
what?
why not ask at HPE. its an enterprise system Business.
why ask in the toy section here./. and not real HP
here is real HP. (i have Proliant servers)
https://www.hpe.com/us/en/support.html
ask on the real HPE forum first. bet wise do that and NOT HERE.
create an account (free)
the look on the hpe forum
here.
see all those other wise users asking in the right place, yes.
https://community.hpe.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=true&q=tape+Ultrium+448
Nov 12, 2017 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Tape keeps ejecting
use Cleaning tape , update firmware .
Mar 05, 2012 | HEWLETT-PACKARD Hewlett Packard HP EH957A...
My Backup HP Tape Drive 232 flusing led "Cean" and "Tape"
This can often be resolved by loading a Cleaning tape. Cleaning tapes are specific for the LTO1 and can be used only a set number of times. This can be caused by a particular tape which is imparting contaminates into the drive. LTO drives should be cleaned when the light flashes only and not after a fixed number of hours.See the HP LTO1 user guide for details.
Jan 11, 2011 | HP StorageWorks Ultrium 232 LTO 1 Tape...
Am cleaning my msl 2024 tape drive but its continually wanting the cleaning
Your heads need replacing this is a common thing, they wear out, and need to be replaced.
May 21, 2010 | HP StorageWorks MSL2024 2 Ultrium 448...
Please I did not find what I was looking for. My problem is that My HP Ultrium 448 Tape Drive has stop working. So I opend the Tape Drive and I found out that the tape has teared and I don't know where...
You can download LTT from www.hp.com/support/tapetools
Stop your backup services and Ran some test
First try to double check your SCSI controller drivers and your drive firmware (With LTT)
May 06, 2010 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Need to clean fan on HP Storageworks Ultrium 448 Tape Drive
here´s a manual
http://www.dectrader.com/docs/set3/emr_na-c00397852-1.pdf
Mar 30, 2010 | HP StorageWorks Ultrium 448 LTO 2 Tape...
TAPE WON'T LOAD
Stop all the backup services.
Run LTT firmware update and some test
Dec 16, 2009 | HP StorageWorks Ultrium 448 LTO 2 Tape...
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
HP (DW017A) Ultrium Tape Drive Logo
830 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
