How can I copy WIndows XP from one hard drive to another so that I can boot off the new hard drive?
I will then upgrade the copy of XP on the new hard drive to Windows 7, so all I need is for my PC to boot off the new hard drive with XP and for the Windows 7 installation to recognise XP on the new hard drive.
Why are wanting to clone your hard drive to another on when all you need to do is install Windows 7 directly onto the new hard drive?
Are you wanting to save all your settings and data before you install Win 7 over the top of XP?
Thanks for the promt reply.
What you are going to need for this is a boot CD. I recommend Hirens Boot CD for this job.
Also take it from me this can be difficult to perform.
First of all make sure you have your new hard drive installed in the desktop and that the BIOS knows the drive is there, it doesn't matter whether Windows recognises the drive.
Next you will need to download and burn off an image of Hirens Boot CD. For this you need burning software installed on your XP operating system.
Download Hirens Boot CD from the link below, scroll to the bottom of the page and click on Direct HTTP Mirror, It will come in a zip file that needs to be extracted to a file. Inside the file it should be an ISO format as well as a text file and burning tool so make sure you read the text file first.
http://www.hirensbootcd.net/download.htm...
When you have burned a copy of the boot disk off pop it in the drive and you can then restart the computer. Set the CD/DVD drive as the first boot device. If you have done this correctly then you will see a message on-screen booting from CD, then choose boot from disc.
You will see a list on-screen. Use the cursor keys to navigate to Backup Tools and choose Norton Ghost and hit enter.
NOTE: Make sure you make a note of which hard drive its there so you don't accidently clone the wrong hard drive as i am not responsible is this happens!!!!!!
If your hard drive is 40GB then it will be 40960MB. If the new drive is 250BG then it's 256000MB. As you can see the numbers are larger with a bigger drive.
Take your time with this so no mistakes can be made!!!!
Once you have set the cloning operation off DO NOT switch your computer off or mess about with it. Just leave it to run its course. It will let you know when the operation is complete, be patient!!
When done shut down the PC, take out your old drive and replace it with the new one. XP should then boot up and allow you upgrade to Win 7 no problem.
Good luck and if there is anything else please post a reply.
Http://www.winsupersite.com/win7/clean_install_upgrade_media.asp
If you have a copy of Windows 7 Upgrade you don't have to perform an upgrade like you would in the past. You can do a clean install with the upgrade DVD.
I would export your settings and files first using.
http://windows.microsoft.com/en-US/windows7/products/features/windows-easy-transfer
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
because the copy of Windows 7 that I have is the "upgrade" version which requires an existing legal copy of Windows (XP in my case) to be present
desktop - I want to remove the small disk currently in the PC and replace it with a larger one and then perform an upgrade to Windows 7 on the larger disk. So I need XP on the new larger drive and then boot and upgrade to Windows 7. The upgrade over XP will completely re-format that drive.
