Question about Gateway GT5692 Desktop Computer
Super,super slow computer - Gateway GT5692 Desktop Computer
    President:
  • 2,291 Answers
If you are looking to increase speed of computer thenmake a firm decision to start performing little tweaks with yourcomputer. The better you manage your computer functions the more fasterit will run. Some people complain that they are using the new Windows 7or Vista but still their systems are severely lagging. It is notpossible to fix such system without the help of some efficient PCoptimizer and registry cleaner that has the power to speed up mycomputer.
Here are given a few techniques which have been foundvery helpful to make computer run faster with Windows 7 or Vista inseconds:
Clean Windows 7 or Vista Registry: The registryof the Windows contains immense information. It shall be cleaned allthe time and it is the most effective way to boost computer speed in aneasy way.
Defragment your PC to increase computer speed: Press Start button > then Programs > Click Accessories > Press System Tools > And Disk Defragmenter.
Thisfeature will take some time but it will compact large data into smallerpieces creating a lot of free space for the computer to run faster. Youcan delete unnecessary files from your computer prior to performingdisk defragmentation.
Add more RAM to Speed up your computer: If you are running a lot of programs and the capacity of your RAM isshort. This will surely help you to make computer run faster withWindows 7 or Vista in seconds. Fortunately it does not take much time.Make it sure that you place it the right way.
Clear Cache, history and temporary internet files: Another way which I assume is a 'best way to speed up my computer' isto clear the cache, history and temporary internet files. Removing junkfiles frees up a lot of space required to make computers run faster.
Turn off unnecessary programs from start up: A lot of computer users complain that their Windows 7 or Vista does notboot faster. I would recommend to such people to have a shorter startup items list.
Have low intensity graphics If you are not an ardent gaming user then you can afford to run computer faster with low intensity graphics.
Uninstall unused software and programs: It is very common that people install a number of computer programs andthen stop using them. These unused programs shall be removed toincrease the computer speed.
The above guidelines were reallyhelpful to speed up my computer. These are safe and do impact computerperformance in a positive way.
Frustrated of the dead slow speed of your computer? Do you wish to speed up computer in seconds? Please remember to clean Windows registry with Intel Software Partner, RegInOut BY CLICKING HERE. After this scan you will feel how much faster is your computer running.
Posted on Aug 20, 2010
  • 570 Answers
Don't worry please just follow the easy steps and fix your problem
  • Use the defragmentation tool (defrag). A hard drive consists of hundreds of sectors which or broken up into clusters and then further into allocations. As a computer gets used the files that are accessed are sometimes not put back to the sector or allocation unit where they belong. The drive becomes “fragmented”. The defrag tool can be accessed by going to the start bar, to programs, accessories, system tools and defragmentation tool. It may take several hours to properly defrag a hard drive, but the resulting gain in speed will make this time well spent. Files will be more quickly accessed and all of the bad sectors on a disk will not contain any information on them. Hence, a user will not wait in vain for a file that is stuck on a bad part of the hard drive.
  • Use registry fix programs. The computer registry can be described as the database that contains all of the settings and options for 32 bit versions of Microsoft Windows (including Windows 95, 98, ME, NT, XP, and 2000.) It also contains all of the settings for the hardware, software, users, and preferences of the P.C. Whenever a user makes changes in the Control Panel settings, file associations, system policies, or installed software, the changes are reflected in the computers registry. Many times a registry error occurs and this causes files and data to be inaccessible. If there are numerous minor errors (which is usually the case) a registry fix program will get the data back in accessible sequence and a slow computer will be speeded up with this fix.
  • Adding more RAM (random access memory) to your system will almost always help speed up a slow computer and the act of multi-tasking will not bog down the computer as it would with a lower amount of RAM. RAM is hardware that needs to be physically added and tends to be somewhat costly. However if you plan on keeping your system for a while it is an excellent investment.
  • For faster browsing speed clear your Internet cache (temporary internet files) and delete your cookies. This causes the computer to gain speed on the Internet and the pop-ups from sites that you have been to will also be less frequent.
  • Remove unnecessary items from the start menu. To do this type “msconfig” in the “run” box and hit enter. Choose selective startup and uncheck all of the programs that you do not need to load every time you start your computer. This will make the computer start more quickly and efficiently. DO NOT uncheck items that you do not recognize. This could cause you computer to run improperly.
  • Use a browser with an integrated pop-up blocker (Firefox for example) to decrease the amount of pop-ups and increase browsing speed.
  • Constantly scan for viruses and Trojans. Trojans can be on a system for weeks even months unbeknownst to the user causing major slowdowns and file errors. Try using a specific Trojan scanner instead of the conventional virus all-purpose scanner. Many Trojans slip past the “big name” virus scanners and need to be sought out specifically to be removed.
Please rate me if this solution works for you
Thanks......Have a great time.
Posted on Jul 20, 2010
How can i get rid of super optimizer
go to control panel then go to programs and features select the program you want to uninstall by right mouse clicking and click on uninstall.
Sep 24, 2014 | Computers & Internet
Slow dell latitud d531
you computer is infected with malware embedded with bugs keep your computer from streaming at fast speed try to down load super anti-spware or superanti-spyware.com
Feb 01, 2013 | Dell Latitude D531 Laptop Computer PC...
It take more than 3 minutes to connect on line,plus the computer moves very slow
have your pc scanned for viruses, viruses tends to cause these, if you finished scanning and theres no virus in your system have your hardware check, by a computer tech. a failing device is reason for a slow system
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
My pc is to low ,and internet run slow
try to remove temp file
remove programs from start up menu
remove unwanted software
increase virtual memmory
Jul 18, 2009 | Compaq Presario 5000 PC Desktop
Asus EEE 901 super slow in the internet
clear temporary internet files and install tuneup utility increase RAM speed
Jul 04, 2009 | ASUS Eee PC 1000H Laptop
Slow Printing color/b&w
are the settings on the computer console program (properties of printer that pops up before you print) set to the best quality? reduce it
May 27, 2009 | Canon BubbleJet i560 InkJet Printer
Eee 1000h/XP wireless internet incredibly slow
Well, based on my PC fix experiences, there are a number of reaons might be responsible for the performance issues, some are dangerous while others not that serious.
You may learn why and how to speed it up easily from: http://www.whyismypcsoslow.net/
Hope this helps, good luck to you & your Eee computer!
Rose
Mar 27, 2009 | ASUS Eee PC 1000H Laptop
Slow running INTEL PENTIUM 3
First thing to do to speed up a computer even with this slow processor is to remove some unnecessary program installed on the computer, then run a good anti virus and anti malware software some Avast and Malwarebytes to make sure that not a virus or malware is causing this slow computer and the best thing to is to add up a Mermoy on your computer that will surely make it much faster....
Nov 09, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
Help computer way to slow
run regid file delete your file.....then start program file system scan your system & Disk Defragmenter ok
Mar 28, 2008 | Computers & Internet
Gateway GT5692 Desktop Computer Logo
137 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
