Question about Dell 1600n All-In-One Laser Printer
The scanner is locked
How do i unlock the scanner on my printer?
    Brigadier General:
  • 10,406 Answers
There's a physical locking-mechanism that is designed to keep the movable parts of the scanner locked into place, while the scanner is being transported. On most scanners, it's either a few screws, or a lever. From the manufacturer's web-site: http://support.dell.com enter '1600' and do a search, and download the Quick Start document, to read the specifics.
Posted on Jul 20, 2010
I am repeatedly getting error code 5010 once I scan any document.
Ok it can be either 2 things: The FIRST is if you have not UNLOCKED the scanner lock switch. The scanner lock switch is a switch that keeps the scanner assembly frozen in place so that when you move your scanner from room to room or apartment to house, the scanner wont freely move around the unit causing it to be dammaged.
To unlock the Scanner lock switch just lift your document cover and look for the swtch on the LEFT hand side of the scanner's glass bed.
SECOND: IF the scanner lock swtich is set at UNLOCK, then your scanner assembly is broken and needs to be replaced. You must then send it to Cannon or any Mulitfunction printer repair place.
I hope this helps you :)
Mar 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
Unlock Scanner message
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
My workcentre pe220 printer's scanner is locked
my workcertre pe 220 scanner locked . how can i scanner unlocked?
Sep 03, 2009 | Xerox WorkCentre 220 All-In-One Laser...
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Unlock scanner
lift up the scanner assembly to expose the underside of the scanner. slide the locking clip up from the locked position to the unlocked position. ( red )
Sep 25, 2008 | Lexmark X5150 All-In-One InkJet Printer
Scanner locked - unlock scanner
To unlock a scanner open it where you would put cartridges in and look for a red or green colored tab hanging down. There should be a little picture of a padlock. You can switch it from lock to unlock. It's kept locked to protect the scanner during shipping.
Hope this is helpful...
Jul 14, 2008 | Lexmark X340n All-In-One Laser Printer
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
Page 51 contains
holds it open.
page iv.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Scanner Locked
On the underside of the scanner assembly is a LOCK, it has two positions LOCK and UNLOCK. The manufacturer sets it to lock so the scanner doesn't move during shipment. You should be able to slide this to the unlock position.
Jun 12, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Unlock printer
Work the lock several times. Make sure there is not more than one lock. Dell web site Tech Support Look in on www.fixyourownprinter.com
May 31, 2007 | Dell A960 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
405 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
