Question about Garmin Nuvi 350 Car GPS Receiver
No Map Data Available on Garmin nuvi350
Maps details changed, Map Info button is grayed out and getting "No Map Data Available" when entering a new location search - state or city, showing "No Matches Found".
  • Garmin Master
  • 6,993 Answers
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Best regards
Posted on Jul 21, 2010
  • marystdmn Jun 26, 2011
    I will try this tomorrow as have to go out to eat
  • Garmin Master
  • 2,130 Answers
Reset has nothing to do with this. If the map key is grayed out, then the map file "gmapprom.img" is missing. With no map file, the only detail on the screen will be the basic highways from the basemap file. You will also not be able to perform any searches, you will receive "No Match Found" error.
The map file needs to be restored.
Please see this link:
http://www.sharc.net/gps_lost_map.htm
- Jim
Posted on Jul 26, 2010
Ok so i have pressed the middle of the screen the message no detailed maps that support routing has gone have gone into address it now says no data available and still no maps
The original message of "No detailed maps to support routing" is typically caused by a missing or corrupted map file. It can also be caused by not having the proper map unlock key installed on the unit.
If that problem has been resolved and you can't obtain an address when setting a route, make sure that the map is turned on.
Go to settings, select the map icon and then the map info button. Make sure there is a check mark in the square next to the text that lists the map that you have installed on the unit.
If the map info button is grayed out, then you still have a map issue.
If the square does not have a check mark in it, press the square to place a check mark in the square. This will activate the map.
With this unit, you can put several maps on it and you can select which map will be active or inactive with the check mark.
More map issues are explained here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Jun 08, 2015 | Garmin nuvi 200W GPS Receiver
Click on address and it just beeps and stays on the same screen
This is an indication that there is a problem with the map. The map contains all of the data regarding streets and points of interest. You can confirm this by going to the map screen and pressing the map info button. If the map info button is grayed out or there is no map listed on this screen or you see a (c) copyright symbol then there is a problem with your map. Please see this link regarding missing maps and how to get this problem resolved.
Mar 10, 2014 | Garmin nuvi 1450 GPS Receiver
Garmin nuvi 200 problems- I press streets icon ----it comes up (NO DATA AVAILABLE).
Make sure that your map is enabled with a check mark on the map info screen. If the map info button is grayed out, then this means that your map is missing.
Jul 08, 2013 | Garmin nuvi 200W GPS Receiver
MY MAPS HAVE GONE FROM MY SATNAV HOW DO I DOWNLOAD NEW ONES
The maps may just be unselected rather than gone. To select them press the spanner icon (Tools) then press Maps. At the bottom of the screen press Map Info and see if there's a map there. There should be a tick at the side of the map name. If there's not press the map name and the tick should appear. The map will then be selected and should be ok.
If you need to get a new map or map update connect your satnav to your computer. Go to www.garmin.com. If you have already registered your satnav click on myGarmin and then on myMaps. (Details on how to register are below) Your map should be shown there and if there's an update available click on GET UPDATE to download the updated map. If there's no update and you need to buy a new one click on Shop For More Maps and select the ones you want. Follow the prompts.
TO REGISTER YOUR SATNAV
Go to www.garmin.com and select your country. Click on myGarmin and then on Register Your Garmin Product. You'll be asked to create a username and password. Keep them safe as you'll need them anytime you want to update your maps.
Aug 19, 2010 | Garmin StreetPilot C330 GPS Receiver
My garmin powers down while installin gnew maps.
There are 2 possible reasons for it to say there are no detailed map available. The most likely reason is that no map is selected. Press Tools, then Press Settings, then press Map and then Map Info. There should be a tick beside the name of the map installed on the satnav. If not press the map name to select it. A tick will appear at the side of the map.
The other reason is that the map may be locked. You'll need to go to My Garmin, and then Maps to get the unlock code.
Jul 30, 2010 | Garmin nuvi 255W GPS Receiver
I have no maps on the screen its like i lost all the data. it says there are no roads near this start point. every thing else works mp3, settings, volume, bluetooth, etc.
it sounds like you may have just deselected the maps.
go to tools settings map then map info(bottom of the screen)
check that there is a tick next to your mapset if not just tap the name of the map and you should be sorted out.
Jul 12, 2010 | Garmin Nuvi 660 GPS Receiver
PROBLEM UPDATING MAPS
Plug your GPS into your PC and do not use the Garmin Express program. It will mount as a drive. Delete the maps and software. Then run Garmin Express and do a complete install of the maps and software.
Apr 04, 2017 | Garmin nuvi 255W GPS Receiver
"No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Dec 12, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 660 lost map data
take it back to the store you got if from and get a tom tom
Aug 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
944 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
