I have a universal remote control that the batteries died. I replaced them with new ones. The remote still does not work. I would like to try to reprogram it, but do not have the code. It is for an RCA telivision. Can someone please help Thank you Jeff
  • 116 Answers
Please provide the brand and model # of the universal remote. Sometimes, the part # is inside the battery holder.
Posted on Apr 22, 2008
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
My phillips universal remote needed new batteries, so i put new ones in, but now it won't work. can you help me?
When the batteries died the remote forgot all the stored codes. All you have to do is to input them again.
Jun 19, 2010 | Televison & Video
Remote doesn't work
Return ur univeral remotes,try this website 1-800-Remotes Factory original to buy a original remote.
Dec 15, 2009 | RCA Universal Remote Control
Samsung TV remote. I noticed today my TV remote wasn't working. I changed the batteries and noticed there had been some leakage from the AAA batteries. Since changing the batteries the 8 buttons on the top...
Giving you some hints. Battery leakage is one enemy of tv control and other remote control. They can corrode your battery spring contact, give contact bridges with neighboring tracks that can cause erratic behavior of your remote.
Some repairs can be done but doesn't guarantee success. First is try to clean the corrosion on battery contact = no power usually. Erratic behavior cause by contact bridging = battery leak residues.
Opening a remote control. Some have screws on its small foot. Covered by a rubber or sticker. Some are notch clip in strategic location you have to fry that one by one, opening first on its weakest side. In some don't want to be open.
Cleaning the board by a soft eraser is one way. After you open the remote. Commonly the button area where contact takes place.
If the first procedure and cleaning doesn't work. Buy new remote or use universal remote controller.
Aug 23, 2009 | Samsung TV Remote Control
My battery dies very quickly.
You need a new battery. I can order one for you if you like.. Please go to my website (www.totalcontrolremotes.com ) and contact me.
Regards,
Vincent
Total Control Remotes
Jan 11, 2009 | Universal Remote Control MX-3000 LCD...
REMOTE SEEMS TO HAVE DIED - RED LED VS GREEN
There is a very strong chance that something foreign has gotten into the touch membrane for your remote control or the link from the touch pad to the circuit board. If it is still under warranty, get it replaced. If it is not under warranty a new universal remote may be on your next shopping list. Repairs to OEM remote controls cost more than a new one.
Hope this helps...
Dec 29, 2008 | Televison & Video
My universal remote control by RCA
take the old battery,and replaced it with a new one..
hope this may help;
DON'T FORGET TO RATE
Aug 23, 2008 | RCA Universal Remote Control
Philips universal remote control cl034
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Try this website it really works. I just tried it today and I am sooo happy.
Jan 23, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
