Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
My murray feiss remote conrol for my fan/light stopped working. we have a switch on the wall also but it just has to be on and then we have to use the remote bought new batteries turned the light on but then went out.
5 Suggested Answers
SOURCE: Remote to fan won't work
Try this link for the ceiling fan remote it should be remote style M. I want a spare so I found this web page (page down)http://www.eceilingfans.com/ceiling_fan_remote_controls.html
Posted on Mar 23, 2008
  • 15 Answers
SOURCE: no connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Posted on Apr 17, 2008
Beelz
  • 666 Answers
SOURCE: I have a Hampton remote ceiling fan with lights.The Redington 11
its more likely the fan itself has burnt out each universal control comes with a means to manually enter a code to if you have one with the manual you amy be able to set the ceiling fan frequency to a preset to be used if your fans remote is the issue
I think before trying to program it into another remote you make sure in whatever way you can that the fan itself can be turned on manually by hand so you know that it is not the issue
hope this helped
Robb
Posted on Apr 29, 2010
Testimonial: "Thank you. Since the lights failed also Iwill have to search further."
Why did fan and lights stop working?
If you are controlling lights and fan only with the remote - no problem. Once you start flipping switches, the remote control loop is broken. You can restore remote control by setting the wall switches to off, turning off power at the circuit breaker (or fuse), and waiting for a few minutes during which you will be removing the battery from the remote and pushing all buttons, then reinstalling the battery. When time is up, restore power and try the remote. If no luck, check to be sure the wall switches are set to off and repeat the routine.
Jan 28, 2016 | MinkaAire F715-STW Sterling Walnut Napoli...
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
I have a Hunter fan with remote and the light flickers without coming on completely - and you can hear a clicking noise coming from the fan. The fan works and the bulbs and batteries were changed
The pins inside the remote could have been switched or the wiring inside the fan could have come loose. Check the wiring at the fan first. The vibrations of the fan could have worked the light conrol wire loose.
Oct 10, 2010 | Hunter 27185 Remote Control
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Can't use Wall Switch to turn on light
The problem may not be with the fan, but with the wall switch. Try changing the wall switch and see if that works, sometimes they go bad.
Jun 03, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
