Question about Lexmark T644 Laser Printer
What does 900.00 rip software mean? - Lexmark T644 Laser Printer
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
This means there is a problem in the software of the machine.
You can try resetting the factury defaults. Turn the machine off.
Press and hold > , v and V .
Turn on the printer.
Release the buttons when resetting defaults displays
If this doesn't help than replace the systemboard.
Posted on Jul 21, 2010
  • 217 Answers
SOURCE: I am getting a message that says 900 Service RIP
This means there is a problem with the engine board. You can try to reset to factury defolds. Turn off the printer, push the buttons 2,3 and 5 and than turn on the printer. When message "reset to defolds" apears release the buttons. If this does not work than you have to exchange the engineboard.
Good luck, Gerrit Jan
Posted on Aug 12, 2009
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
SOURCE: 900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
Posted on May 24, 2009
  • 217 Answers
SOURCE: 900 service rip software error
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
Posted on Apr 08, 2010
Mrinny
  • 94 Answers
SOURCE: What does 900 Service RIP Software error message
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Posted on Aug 02, 2010
How to download adobe in design cs 4 from cd?
If you mean to RIP a binary image of the CD then you need software such as Power ISO.
Nov 17, 2011 | Sony Computers & Internet
I got message (900.00 service rip software) on my lexmark T644 printer. What does this mean
900 rip is a inrecoverable software error POR printer take data cable out and POR should clear if not then system bord needs replacing more likley corupt dat sent to printer
Sep 16, 2011 | Lexmark T644 Laser Printer
The rip on the copier is flashing FF and I am not able to print. What can I do to solve this problem?
Hello. The FF is a hexadecimal number that means the rip did not boot properly.There are buttload of reasons why this my be but lets try this. Power off the copier and the Fiery emulator (rip).Power on the copier only and let it reach aready condition.Then energize the rip and watch the same display that showed the FF.It may take a minute or two as it goes thru its boot/diagnostics,but we hope you dont get the FF again.Now I am assuming that what we are talking about is a previously configured system that had been working fine until recently.If this is so,and the rip does not operate correctly after the directions I just gave then you probably need to re-load the rip's system software.
May 27, 2010 | Canon imageRUNNER C3220 Color Copier
T644 won't print - message says "900.43 Service RIP Software" - What does that mean??
It means the RIP board is bad. It's under the left side cover. I think the board is around 100.00 and easy to replace. Steven 805-520-3003
May 13, 2010 | Lexmark T644 Laser Printer
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
Apr 07, 2010 | Lexmark Optra S 1855 Laser Printer
Rip software code 900
Please contact the IBM Printer Technical Support for more exact information.
A 900 RIP error means that you have a down-level firmware build on the printer. Its a software bug that was more than likely fixed in later issues of code.
Normally all you have to do is download the newest firmware build and then follow the instructions to upgrade the printer.
Don
Nov 23, 2009 | IBM Infoprint 1612 Express Printer
Don't know how to rip dvd...cd works just fine
now a days,, rip dvd is very easy,, go to google.com and type ripping tools, which will guide you a variety of software tool programs freeware and shareware,, install one and check..
Sep 28, 2009 | Sony VAIO VGN-SR240N/B 13.3-Inch Laptop...
Dvd player not ripping
If it reads but not rips can mean 2 problems. One is your burning ROM, try changing your software and burn the files. Two is that your burner is dieing
Jul 24, 2009 | HP Computers & Internet
I have a Xerox Docucolor 12 printer which uses a RIP to process files you send from your computer in order to print them in the Docucolor. The RIP model is Splash G640 in an Apple G5 power pc. I have...
get the cables checked and replaced if still the same problem.the software which you are loading from internet are missing some files
the orignal software from xerox is required.
Jul 19, 2009 | Computers & Internet
Abs
There are speed sensors for the abs in the front wheel bearing assemblies. Rust builds up and changes the air gap between the speed sensor and the reluctor ring inside of the hub. The rust needs to be cleaned away to restore the proper air gap it fix the problem.
Sep 03, 2008 | 1997 Chevrolet Blazer
Lexmark T644 Laser Printer Logo
486 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
