Question about Epson Perfection 1200 Photo Flatbed Scanner
Can I get a driver for the epson perfection 1200 scanner that is compatible with windows vista. at present it will not work with vista and I am told no driver is available, otherwise I have to buy new scaner.
  • 700 Answers
This is pretty ancient model, but... you can try to use winxp twain driver and it should work, your registry most probably will need bit of tweaking... version which will most probably work is TWAIN Driver v5.53A,
follow this procedure, disconnect your scanner from computer, run ccleaner to clean all rubbish, including registry clean.
download twain driver and then run it, force vista to accept it, reboot your computer. connect scanner and you will have then warning from vista about digital signature, disregard it and force install software. scanner should work.
i still would suggest newer version...
Posted on Jul 20, 2010
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
I can not install my Epson scanner perfection 1200 photo on my laptop vista 32bits OS?
It all depends on what driver you have, it would probably be best if you went to the Epson web site, followed links for support and downloads and downloaded the latest driver for you scanner/operating system.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14557&prodoid=8161&infoType=Downloads&platform=Windows
When I say that, I've just had a look and it maybe the case that this scanner isn't supported for Vista and beyond.
My only other suggestion to use their contact us link and ask them.
Oct 29, 2010 | Epson Perfection 1200 Photo Flatbed...
Epson perfection 1200 photo scanner won't work now I have changed to Windows 7. I cannot find any software update to help.
Okay, after careful investigation I have found that your scanner is not windows 7 complaint there fore there is no driver solution for this scanner. If you read below the last operating system this worked on was NT
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQs&oid=14557&prodoid=8161
Now if you have windows ultimate you can run a virtual machine on this and hopes it will work, Also a dual boot will be a solution as well. Otherwise its not compatable.
Thanks and pelase do be considerate when leaving a rting to this fact.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 26, 2010 | Epson Perfection 1200 Photo Flatbed...
I want to upgrade my Epson Perfection 1200 Photo flatbed scanner so I can use it in Windows XP
Are you talking normal XP or something more specialist...If normal just download the twain driver from the epson site. I cannot get the copy utility to work but the twain give you the functionality to scan. Following the other threads here I have been able to get this scanner two work even better on 64bit Vista
Jan 05, 2010 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection 1200 Scanner Driver Needed for Windows 7
I posted this for another user but i'll post it here too,
I remember looking for hours for a driver for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit, eventually I found one. Just today I upgraded him to Windows 7 64 bit and remembered I couldn't get it to work, luckily I was able to dig up the driver I used for Vista 64. Worked great in Windows 7.
I can't remember where I found it so I can't credit the person who made the driver unfortunately, however i've uploaded it to Rapidshare for you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
Dec 16, 2009 | Epson Perfection 1200 Photo Flatbed...
Any chance of a driver for Epson Perfection 1200 scanner with windows 7 64bit
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Dec 15, 2009 | Epson Perfection 1200 Photo Flatbed...
Looking for drivers for epson perfection 1660 photo scanner on a windows vista 64bit system. any help would be welcome. thank you
Vista x64 and Windows 7 x64 driver for Epson 1660 scanner is found here:
http://www.vistax64.com/drivers/185132-unofficial-drivers-epson-perfection-1660-scanner.html
Apr 16, 2009 | Epson Perfection 1660 Photo Flatbed...
No drivers for windows vista
Perfection 1200U Photo Scanner for Vista
Jul 11, 2008 | Epson Perfection 1200 Photo Flatbed...
Epson scanner perfection 1200u photo
The driver listed on the web for 2K is compatible with XP.
1) Go to the website http://support.epson.com
2) Under the SCANNERS heading select Epson Perfection Series and then your scanner model.
3) Under the Drivers & Downloads section select Windows. Download the most current driver for your Windows operating system.
4) Follow prompts through survey and license agreement. Choose to SAVE this file to your DESKTOP.
5) When the download is complete, double-click on the Epson icon on the desktop. This will automatically extract the files and begin the SETUP.
6) Follow the prompts to install the scanner, and click on FINISH when prompted.
7) At this point reconnect the scanner to the computer.
8) You will see an ADD NEW HARDWARE WIZARD. Make sure INSTALL THE SOFTWARE AUTOMATICALLY (Recommended) is checked and click NEXT.
9) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
10) Your scanner is now installed. Restart your computer before testing.
Dec 03, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection 1200 Photo Flatbed Scanner Logo
615 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
