Question about LG WD-12126RD Front Load Washer / Dryer
LG intellowasher wm-10240F - don't know how to get it to spin
I have a LG Intellowasher 7k wm-10240F (or CF) it washes ok but does not spin there are 2 buttons at the front of the washing maching I think 1 is rinse and 1 spin they are making a noise and flashing but I don't know what to do next to get the spin working?
thanks for your help
SOURCE: LG Intellowasher - CL in led code whats wrong?
had this prob too. took me a while to work out. CL is Child Lock... hold down 'Rince' and 'Prewash' buttons at the same time to unlock.
Posted on Aug 13, 2007
  • 1382 Answers
SOURCE: My LG Intellowasher WM-1280FHD is refusing to
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Posted on Jul 14, 2010
caroldon
  • 17130 Answers
SOURCE: MY LG INTELLOWASHER MODEL 10240F IS TRIPPING EARTH
If the total connection to the motor was removed and still the ELCB trips off, then the fault seems to be with the main controller unit. There is an error in this unit that is causing the program to make the error when the program activates the wash stage. It can varry from a short in the drive to a leak inthe drive.
So the best way to look is to disconnect the drive/pre-drive of the motor.
If the trips stops then you will find this drive as the suspect.
Posted on Sep 08, 2010
SOURCE: I have an intellowasher made by LG WD1023C I have
This means -Child Lock trying to solve the problem myself- I think by pushing 2 buttons together... but which ones?
Posted on Oct 22, 2010
Andriod Man
  • 271 Answers
SOURCE: wash cycle works ok but
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Posted on Feb 09, 2011
Lg wm-10240f wont spin but washes fine cleaned pump
Google hall sensor or motor position sensor on lg washer.
Mar 10, 2015 | LG Washing Machines
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
Feb 09, 2011 | LG Washing Machines
My LG Intellowasher WM-1280FHD is refusing to spin, even when empty, making strange noises and displaying the code LE. I cannot find the manual to know what this means. Can anyone help?
Thank you !!
Jul 14, 2010 | LG WM-2277HW Front Load Washer
Can't get beyond the filter to get objects out
You could fry blowing hard down the the outlet hose, this may dislodge it.
The only other way would be to remove the pump from the washer, and retrieve it that way.
Hope this helps.
Jan 22, 2010 | LG WM-1480FHD Front Load Washer
Lg intellowasher model wm 1290fhb door will not open. tried waiting 1 hour! tried power on and off, tried child lock
  1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
  2. Press the Power button, while pressing the SPIN SPEED and SOIL LEVEL buttons. Then buzzer will sound twice.
  3. Press the Start/Pause button repeatedly with about 1 second interval until the lamps goes out.
  4. The washer powers off and unlock the door.
Oct 18, 2009 | LG WM-1290FHB Front Load Washer
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
LG WD-12126RD Front Load Washer / Dryer Logo
102 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
