Question about Kenmore 94812 Top Load Stacked Washer / Dryer
Water does not drain, strange noise while in spin cycle
Washer agitates fine, but when it comes to the spin cycle the water does not drain, and there is a clicking/slight grinding noise. When you turn off the machine while spinning, there is a loud whirring noise(like something is spinning inside extremely fast) We checked to see if anything was caught inside, but nothing there.
Any advice?
Thanks in advance!!
  • prd2bcndn Apr 24, 2008
    Wow, thank you very much! It ended up being a children's sock in the drain hose!!
  • 487 Answers
Sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Posted on Apr 22, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Not getting any water?
very strange problem.. there is a unit within the washer that does not allow it to start agitating untill the water is at the level desired. its very clever name is water level indicator valve the valve must be jammed closed there fore the washer thinks the barrel is full of water and goes strait into wash cycle. i would say replace the w/l/i and youl be fine
good luck
Jul 12, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Problem with a indest wil143s
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 06, 2009 | Washing Machines
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Won't spin or agitate
Sounds like a burning out motor to me...
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 94812 Top Load Stacked Washer / Dryer Logo
412 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
