Question about Olympus X785 Digital Camera
My Olympus X785 Digital Camera received a slight knock and the lens won't open now when I switch it on. It makes a noise as if its trying to come out but it wont.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 21, 2010
Why is my Olympus FE430 camera zoom lens jammed?
Either it has received a knock or other accidental blow, or else there is foreign matter (dirt, crumbs, grit etc) in the mechanism. It would cost far more than a replacement camera to have it serviced, I'm afraid, and is certainly not the kind of task to be attempted without expert knowledge.
Sep 25, 2016 | Olympus Cameras
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
Olympus X-785 driver download Digital camera for windows free
Having received no response in over a month to my query, I assume my suggestion to use a card reader solved the problem.
Apr 08, 2011 | Olympus X785 Digital Camera
My camera lens won't go in and makes a funny noise everytime you try to turn it on. what's wrong?
my camera fell and tried to get the lens inn and now makes a funny noise and does not open
Jun 25, 2010 | Olympus FE-20 Digital Camera
I have an Olympus X785 which is having problems focussing on shots in the dark or dim light. Any help appreciated
Some cameras have a low light focussing light built in. If yours doesn't, then you will experience problems in low light.
Dec 07, 2009 | Olympus X785 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
The lens on my Olympus m760 camera is stuck in its out position. Even When i turn my camera off or take the battery out, the lens stays fully zoomed out and makes a funny noise like its tyring to retract....
this is probably caused due to a fall or so.. try to technically have a 360 look at the sides of the lens were at one instant u will notice a slight droop.. now u have to carefully push the lens in carefully with **** like motion for which a click noise will be heard... and will go back in...
Sep 16, 2008 | Olympus Cameras
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
Lens
The very delicate and fragile lens mechanism has been skewed by that knock. Try Olympus for a repair price but I suspect you will be buying that new camera once you see the price
Sep 30, 2007 | Olympus Stylus 720 SW Digital Camera
Olympus X785 Digital Camera Logo
61 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
