Question about Kenmore 72062 Gas Dryer
Kenmore model 110.72812100 will start, heat, and
Kenmore gas dryer model 110.72812100 will start, heat, and then the burner goes out. I have taken the back off and there are no obstructions to air flow. Where do I go from here? I don't have an electrical drawing to help.
    President:
  • 1,554 Answers
The issue is with the gas valve solenoids getting weak when heated resulting in the closing of the gas valves and going out of the burner. Replace both solenoids to address the problem and put the dryer back into normal operation. The solenoids are part numbers 694539 and 694540.
Pull the lint trap out then remove the screws under it.
Pry the top cover as shown then raise it to the rear of the dryer.
Remove the screws attaching the front panel to the cabinet then lift and remove the panel. Replace the solenoid coils then reassemble the dryer in reverse ordeKenmore model 110.72812100 will start, heat, and - 35e18ab.jpgsassembly steps.
Posted on Jul 20, 2010
Kenmore model#110.72702101 starts up,heats then burner stops won't relite
If what your seeing is that the flame starts out and goes off and a few later later the igniter glows but no flame??? then the cause of that is going to be the coils on the gas valve are weak and not opening. This tip i wrote explains what is wrong when a gas dryer starts heating but after a while wont heat. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 13, 2011 | Kenmore Dryers
Kenmore elite gas dryer model:110.70982990. Burner will ignite and burn for about 5-10 seconds then goes out. If started again, dryer does the same thing.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 30, 2011 | Kenmore 63942 Dryer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
heatman101';
Jul 05, 2011 | Kenmore Dryers
Kenmore gas dryer does not get hot enough. Gas burner does not seem to stay on long enough. Model 110.72912100
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Kenmore Dryers
I have a Kenmore Elite Oasis gas dryer Model # 110.77052600. The gas and electrical supplies are ok. I have no flame or glow at the burner. What are possiable causes?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Dryer starts with the burner coming on then its wont fire again durning the rest of the cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 06, 2010 | Kenmore Dryers
I paid to have jahn27 solve my problem with kenmore model 70172 dryer (burner cycles such that clothes don't dry. he recommended replace of both burner coils which i did but burner still cycles). how do i...
heatman101
Aug 11, 2010 | Dryers
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
Dryer will turn and start heating then goes out...it's gas
Coil valves need to be replaced.they are the 2 black rounded on top of module where gas line goes into.aout 35 bucks for both.
Mar 28, 2009 | Kenmore 74602 Gas Dryer
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Kenmore 72062 Gas Dryer Logo
246 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
