Question about HP Computers & Internet
I am operating on Windows 7 and I get this meesage
I am operating on Windows 7 and I get this message every time I log on. "Do you want this program to make changes to your hard drive?" SSBkgdUpdate.exe
HOW DO i GET RID OF THIS
  • 109 Answers
You will have to access msconfig this is very easy, clikc on Start then in "Search programs and file" search bar, enter: msconfig
this will open a window and you will have to go to the startup tab and deselect the SSBkgdUpdate. this will stop it from looking for the request to make changes to your harddrive. hope this helps
Posted on Jul 20, 2010
I installed pop up catcher instead a log in for parental control pops up, how do I get rid of it
Did you delete the program folder, or did you use Windows 7 to remove the software. Using the control panel software removal tool reaches into the registry and removes the items.
To recover, you may need to reinstall, and then uninstall using an uninstaller program. Windows 7 control panel will do it, or download and install CCleaner or Revo Uninstaller (Free versions) to completely remove the software.
Mar 03, 2015 | Microsoft Windows 7 Home Premium 64BIT...
Message on screen
insert the windows 7 home premium cd and re-install windows live or restore to factory default settings of your system
Jan 27, 2014 | Microsoft Windows 7 Home Premium 64BIT...
How to delete notepad logs from certain files
if you are using the windows 7, and want to delete any log file which shows 'access denied' , you just need to login with your admin account and you can access and delete that file easily.
Nov 29, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 1 Repeat a Message
  • 0 then 2 Playing Incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop*
  • 0 then 8 Greeting Message Record/Stop*
  • 0 then 9 Answer System Off
  • 1 then 0 Help Guidance
Jan 23, 2011 | Office Equipment & Supplies
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
I have win 7 and this item comes up in the compatibility section as oknown item
Give decent error messages and descriptions.
Compatibility section could be any of a dozen things.
HP doesn't make Windows 7 anyhow, so you can just log something in the proper category next time and get closer to an answer much faster next time, can't you?
Nov 10, 2009 | HP Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
