Question about Garmin Nuvi 760 Car GPS Receiver
HOW DO I IMPUT THAT WE ARE A MOTORHOME
THE PROBLEM IS THAT WE ARE DIRECTED ALONG SOME LANES WHICH ARE REALLY NOT WIDE ENOUGH FOR A MOTORHOME ESPECIALLY ONE TOWING A SMALL CAR ON AN A FRAME.
  • Garmin Master
  • 3,289 Answers
Unfortunately - the only choices for "usage mode" in the nuvi 760 are Automobile, Pedestrian and Bicycle. Check to see if it is not already set to Automobile by touching:
TOOLS -> SETTINGS -> SYSTEM -> USAGE MODE
and select Automobile.
Please rate this replay - and good luck!
Posted on Jul 23, 2010
Thin black horizontal line at top of lg 60 in. tv. Line appears on both HDMI imputs,
Only at the top??? Really? Go into your settings use your remote obviously, click on menu, and go to picture settings. I have an LG TV as well, Im thinking the remotes should be relatively close enough to the same. Look for you screen settings in your menu
Dec 02, 2016 | LG Televison & Video
I purchased a used Lane dual recliner that has to have some type of device to make it recline.
Possibly a remote control. Contact Lane's direct.
Lane Furniture Contact Us Call 800-225-0265 for Customer Service. Customer Service Hours: 8:00am - 5:30pm ET
Reclining Sofas
May 21, 2016 | Furniture
Diesel 1977 mazda parkway motorhome
Yes if the fuel level is low enough
May 27, 2014 | Mazda B3000 Cars & Trucks
A motorhome with Hp of a nissan z24 engine, can it climb steep altitudes? i.e. Andes mountains or the weight of the motorhome would be too much for the engine?
A few ideas. 1) Try the motor home where you are now and see. Find some REALLY steep hills or something and try it out.
2) If it is an automatic transmission, you may need to purchase a "transmission cooler" kit to add on before you try mountain climbing.
3) If it is a stick shift, take along another clutch disc and pressure plate and throwout bearing in case you burn yours up.
4) And remember, cars and trucks that normally operate at sea level will not do well in high mountains. They need to have the timing and/or carburetor set for high altitudes.
5) Many countries outside the USA have different octane ratings on their gasoline, you will need to take along the stuff to set your engine to the octane rating of the gas you buy.
Be blessed
Oct 07, 2013 | 1987 Nissan Pickup
Do you want hints & tips on Motorhome problems?
not really unless you want to answer questions on here for free
Nov 29, 2012 | Cars & Trucks
I have an 32 inch LCD tv which is about 2 yrs old. Was watching tv when the screen went from normal viewing to zoom1. Followed directions from manual, which said to select imput on the remote then select...
Try this. On your remote control there should be a button that says "Aspect" hit that button and it will probably say "zoom1" or "zoom". If you continue pressing the button it will give you several option. My TV is set to "Wide" which is what I am sure yours should be as well. Or simply continue pressing the button until the picture is at the setting you are accustom too.
I hope this helps with the problem,Jason
Jan 02, 2012 | Televison & Video
I have a 2004 CR125R that i baught in 2006 brand new it has less than 20 hours on it. ever since i've got it, it hasn't liked anything other than high rpm/powerband...if im just riding along at...
Reason is pretty common as these 2 stokes and all 2 strokes they really only designed for one thing - Wide open throttle ! Race track performance. short bursts of flat out to clear all fuel and oil enough to idle through tight corner then straight into wide open throttle again.
Some alternatives for you to try would be lean out the fuel air screw just tiny amount 1 / 8th off a turn in. See if bit leaner setting helps your low RPM a bit also you could consider less oil in the fuel mix 32:1 is pretty high on oil. Most would run these at around 40:1 at the track you don't need to make big changes just adjust to 36:1 first just to check the results - you will soon know if is improvement or not ?
Only change one thing at a time then test ride or you will never know the right direction if the change helps then great but if no change or worse, put it back to original setting and try something else until you find the right direction If the bike is at its best flat out then there cannot be to much wrong thats actually perfect really! so just some very fine tuning should get you where you want to be - Good luck! regards Jamie
May 27, 2011 | 2004 Honda CR 125 R
Imput problems with Samsung DLP TV
The parts required for this are available but difficult to find. The overall repair is not that difficult for anyone that has fixed these before. You'll spend more time getting to the jack than replacing it. Try calling Samsung parts and give them the model as well as the circuit designation of the jack. This designation will be written on the PC board. For less than $5 you should be able to get the jack. Ask a local service shop to install for you and you are off and running.
Dan
Aug 12, 2009 | Samsung DLP HL-P5663W 56" TV
460 motorhome fan belt slipping
Check and see if the pulleys are shiny looking, also are the batteries low on charge, if you have more than one battery the load on the alt is huge, add in a low or bad set of batteries and then the belt can deliver enough power to spin the alternator, and it slips. Worked on motorhomes for year's, saw this allot.
Nov 24, 2008 | Ford E-Series Cars & Trucks
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
Garmin Nuvi 760  Car GPS Receiver Logo
83 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
