Samsung clp510 replaced transfer belt, imaging unit and fuser. Was getting a lighter 1" strip across top of landscape full color page but now am getting what looks like three water spots.
    Genius:
  • 1,040 Answers
visit to the given link and download the service manual of your gadget, It will solve your problem...
http://www.givemefile.net/smanuals/printers/samsung/file/36419.html
Thanks
Posted on Jul 20, 2010
  • maryanne921 Jul 20, 2010
    I have the hard copy of the manual. I want to find a solution to the "water spots" which I believe are caused by wrinkles in the fuser roller.
I have Konica Minolta 4650 DN. I printed out a dark picture and put the paper back in the printer by accident. Now all my pages print smudged broken lines going down the paper. Please help me!
Just print 20 or 30 pages with nothing, or only a little dot or something. Your printer is polluted and needs to be cleaned. Sometimes it is enough just to run a few empty pages. If this isn't enough, look at your manual how to clean your drum and fusing unit.
Oct 03, 2011 | Konica Minolta magicolor 4650DN Laser...
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
I have a Xerox Phaser 6100. I just replaced the imaging unit and the transfer belt. Now my copies are coming out with lines across the whole page. one page that I printed came out wiht all colored lines...
Try doing a "stop test." Stop the print process at various stages, and see if which component creates the defect.
For instance, if a print takes 20 seconds, during the first 10 seconds, the drum is generating the image to transfer to the belt. If the image is bad on the drum, then that is your culprit. If not, then see which unit creates the problem.
Also, what color is the line?
After the unit gets to the transfer belt, you should check the transfer roller and fuser.
Whit www.iteminconline.com
Jun 07, 2011 | Samsung CLX-3175FN Printer
Black line across the top of every print on bh c250
Hi first do a cmyk test chart of each color if it happens when you do black copies then check the black imaging unit as it is not being cleaned and will give you black lines replace black drum unit
if it is on color copies black copies then the other thing to look at is the transfer belt unit and you may need to change the transfer belt
do the CMYK and you should get each color fully covered on each page see if there is any lines on the sheets in the same area you are getting the lines if so replace that color drum
Feb 12, 2011 | Minolta C250 Color Copier
SAMSUNG CLP600 COLOUR QUALITY
I've had the same problem with color problems, especially with cyan (blue). I have found that many of the toner cartridges I receive are defective. When I receive a new one, I try it out for a few pages. If the color isn't perfect I return the cartridge and get a replacement. After 1-2 tries, I get one that puts down good color. (A really bad solution I know, but it does get the job done.)
Apr 01, 2009 | Samsung CLP-600N Laser Printer
Ricoh Aficio CL3500N is now printing all documents with lines/streaks all down the left margin of the page. What do I clean or replace to get rid of these unsightly lines printing on every page?
you can try printing a page in black only, then one page each in the 3 other SINGLE colors: Cyan, Magenta, and Yellow. this will eliminate/ confirm one of these causing problem.
the replacement of Transfer Belt Cleaner or Cleaner Assembly is another to try after the above separate-color thing. see if there's a status page of life remaining on replaceable items, including the Transfer belt assy.
i'll assume you didn't scan the job- - this isn't a multifunction scanner/printer type machine?
ok, next in line is to check the Fuser unit, the part on the upper left side/top of printer. if the same streaks appear on the Main fuser rollers, these fuser units cost about 350 bucks. there is also a Fuser Kit, which costs much less, but its job is to add Fuser Oil to the fuser unit and keep paper and ink from sticking.
a guy could suffer sticker shock from the costs of running one of these, considering you could drop a grand buying all 4 drum units, a fuser unit, and a transfer belt assy. . . .
Feb 16, 2009 | Ricoh Office Equipment & Supplies
Fuser
The fusing unit uses heat and pressure to bond the toner to the paper. Normally poor fusing is evidenced by repeating images or by the print smearing when you rub your fingers across the paper. One fuser roller (the heat roller) is probably aluminum with a teflon coating and the other one (the presure roller) is a type of rubbery material and is often orange.
By your description you mentioned cartridges and that the printer is a full color printer. Is this a laser printer having toner cartridges and imaging units? I just want to make sure you do not have an inkjet printer as they do not use fusers.
The washed out prints you speak of sounds more like a transfer issue such as the transfer belt, transfer charge roller, etc...
Please tell me the brand and model of your printer and I will be more specific.
Nov 11, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printing Problem!
franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Aug 25, 2008 | HP Color LaserJet 2600n Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Samsung CLP510
look at the fuser also!
Aug 22, 2007 | Samsung CLP-500 Laser Printer
22 people viewed this question
k24674
jasbo
jasbo
