Question about Epson LX-300+ II Matrix Printer
Epson lx 300+II printer driver problems with windows xp
  • 10,421 Answers
5 Suggested Answers
SOURCE: Epson LX-300+II, the font problem
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Posted on Sep 08, 2008
printech
  • 159 Answers
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
MUKHTAR
  • 2022 Answers
SOURCE: epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Posted on Feb 15, 2010
  • 1027 Answers
SOURCE: No printer driver for EPSON
Trying driver for Windows Vista that you can download on this page:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=75683&infoType=Downloads
If I could be of further assistance, let meknow. If this helps or solves the issue, please rate it and give a testimonialfor my response.
Posted on Jul 11, 2011
Wipro lx 540 dot matrix printer driver software for windows 7
DONT WORRY,
YOU TRY EPSON LX 300 DRIVER (IT IS ALREADY AVAILABLE IN WINDOW XP'S DRIVERS DATA)
YOUR WIPRO LX 540 PRINTER PERFECTLY WORK IN EPSON'S LX 300 DRIVER FILES
Jul 31, 2013 | Computers & Internet
NEED DRIVER EPSON LX-300 FOR WINDOWS 7 ULTIMATE
i need to install epson lx-300+ii for win 7 what can i do?
Feb 14, 2012 | Epson LX-300 Matrix Printer
How to install EPSON LX-300+II without using a cd or usb?
you can download drivers from the epson web site...
good day
Nov 04, 2010 | Epson LX-300+ II Matrix Printer
How do i install an epson lx 300 printer to a vista machine using a parallel to usb converter? i can't locate nor create usb 001 port with the driver cd of the said printer.
1. Start
2. Settings
3. Printer and Faxes
4. Add a printer
5. then Next
6. then Next
7. then Next
8. then Next
9. select Manufacturer name : Epson
10. select Printer name : Epson LX-300
11. Next
12. Windows will automatically install the driver for your Printer
Jun 21, 2009 | Epson LX-300+II Matrix Printer
NEED DRIVER EPSON LX-300 FOR WINDOWS VISTA
ayundenme porfavor nesesito el driver para una epson lx 300 pero para windows 7, el en SO solo encuentro el driver para epson lx 300+ II y no imprime correctamente por favor ayudenme
mi correo es jdiego.mdz@gmail.com
Mar 03, 2009 | Epson LX-300 Matrix Printer
Poor print quality of pdf documents on Epson LX-300
PDFs are designed to print using Postscript language.
The problem will occur with any non-Postscript printer. You can get better results on Windows printers by clicking on the "Advanced' button in the Print dialogue window. Then check 'Print as Image'.
This has worked well for me.
Dec 10, 2008 | Epson LX-300+ II Matrix Printer
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
