Question about LG Art Cool LA1000PR Air Conditioner
Installed an artcool in my appartment and it constanly leaves a little puddle of water on the floor, irregardless of the temp setting or the fan speed. Drain hose is connected to the plumbing drain. Water builds up around the two insulated hoses at the bottom of the indoor unit. someone told me the unit to strong for my appartment, another said not enough refrigerant coolant. It's only 3 months old, LG (life is not so good!)
    Problem Solver:
  • 13 Answers
First of all check the outdoor unit if it is in your reach  than simply touch both the valve & feel the temp if smaller valve is colder than the bigger one than surely the problem is with refrigerant quantity.
Posted on Jul 25, 2010
I have a Superflue electric fired gas powered water heater. For the last 3 months it will quit working there will be a little tiny puddle of water on the floor. Our plumber who installed the heater came &...
See page 15-16 of owners book
d55i3tvttakuaaaaaelftksuqmccaa==
You may need expansion tank, as water heats ether may not be enough space for water to expand as heated. perhaps a different plumber or company.
Oct 26, 2017 | Water Heaters
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
When it rains puddles of water on the passenger side floorboards mostly in the back not coming from sunroof and theres a crack in my windshield thought it might be that but the dashboard is never wet so...
The cowl drains could be clogged. Trace from the opening at the base of the windshield down to door hinges and look for debris such as leaves in the opening behind the hinges. You may have to use a coat hanger as a special tool to remove the debris.
Oct 10, 2017 | Cadillac Catera Cars & Trucks
My 1999 suburban sat for a week while I was on vacation, It might have rained a little bit while I was gone. When I went to turn the fan on I blew to fan motor only to find out a puddle of water had built...
sure... the grill under the wipers is the fresh air intake, i would recomend cleaning it best you can by hand, removing leaves, pine straw, etc, then put a empty pan on you floor board, so you don't ruin carpet, then take a mixture of 1 cup bleach to 1 galon of water ( hot works best) and pour in the grill area... look to see if you see water driping or flowing under car on passenger side. then check your pan inside the car if pan is wet, look for tube under the car passenger side, this is your drain, if it is dripping, get a metal coathanger or a long rod and stick in tube to unclog it. i would recomend this treatment or just rinseing with water once a month or so to keep it open and clean.
Dec 23, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Radiator fans don't keeping running to keep the temp constant of the coolant
the fan only runs when the coolant temp reaches 225-230 degrees F, the temp will not remain constant, it will climb towards hot and then the fan will engage and bring it down, this is normal operation
May 17, 2010 | 1999 Pontiac Bonneville
Freezer temp risen to over 50 degrees. Refrigerator temp also risen to over 50 degrees. Water puddle on floor.
Check the fan in freezer is it running? Check the fan by the compressor is it running? Is the compressor actually running? Be careful can be extremely hot.
Nov 13, 2009 | Refrigerators
Freezer cooling. Refrigerator colloing on 10 setting only
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 17, 2009 | Sub-Zero 690 Side by Side Refrigerator
WATER PUDDLE ON FLOOR
no water will be coming from that line it is going to be a blocked drain line or a rust hole under where you can't see
Apr 17, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
LG Art Cool LA1000PR Air Conditioner Logo
118 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
