Question about Exercise & Fitness
Lost the instructions for my AB body trimmer its an excersise machine
Body by jake ab scissor is broken
I just fixed one for a friend of mine. The rectangle tube goes inside the square tube for handles and is welded. The problem I think is the heat from welding changedo the hardness of the metal and it breaks instead of bending. I fixed it buy welding two 1/2" X 4" solid still bars inside the broken tube. Thereason is no way that joint will break now. Somewhere else, maybe, but not there.
Mar 27, 2013 | Body by Jake Ab Scissor Exercise Equipment
How do I properly use an ab crunch machine?
Begin by positioning your body on the machine with your feet firmly behind the ankle holds. Hold onto the handle bars above and maintain good posture. Using your abdominal muscles, curl your upper body forward while exhaling, using the machine to guide you. Once you have reached the maximum extension, slowly return to the starting position while simultaneously holding tension in your abdominal muscles. Ensure to select a suitable weight for yourself.
Aug 05, 2012 | Exercise & Fitness
How do I properly use an ab roller?
Follow the following steps:
  1. Kneel on the floor and hold the ab roller in front of you with both hands
  2. Place the ab roller on the floor in front of you so that you are on all your hands and knees (similar to a kneeling pushup position)
  3. Slowly roll the ab roller straight forward stretching out your body. Try to go down as far as you can without letting your body touch the floor. It is very important that as you do this, you breathe in.
  4. Pull your body slowly back up to the starting position; breathing out as you do so.
An image of the third stage in the process.
Aug 02, 2012 | Exercise & Fitness
How do I get a manual for different excersises for the Jones machine
Go to www.beyondmoseying.com click on commercial exercise equipment then strength & circuit then the Jones Machine their is a video that will show a number of exercises that cam be done with this unit or just call BodyCraft @ 1-800-990-5556 and see if they have a manual that shows how to use the equipment.
Jun 11, 2010 | Bodycraft Jones Lat Attachment with...
Yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 12, 2009 | Yard Machines Garden
Saftey rules
There is a risk assumed by all individuals who use this type of equipment. To minimize risk, you must follow these rules:1. Inspect equipment before each workout. Check that all nuts, bolts, screws and pop pins are in place and fully tightened. Also, before use, check cables for signs of wear. Replace all worn parts immediately. Never use machine if any parts are damaged or missing. FAILURE TO FOLLOW THESE RULES MAY RESULT IN SERIOUS INJURY. 2. Keep clear of cables and all moving parts when the machine is in use. 3.Always make sure all Snap Links are closed when doing any cable/pulley/strap exercises. 4. Exercise with care. Perform your exercises at a smooth moderate pace; never perform jerky or uncoordinated movements that may cause injury. 5. It is recommended that you should workout with a training partner. 6. Do not allow children or minors to play on or around this equipment. If unsure of proper use of equipment, call your local Body-Solid distributor or the Body-Solid customer service department at 1-800-556-3113. 8. ARNING: Consult your physician before starting your exercise program. For your own safety, do not begin any exercise program without proper instruction. Including maintaining the equipment the owner’s responsibility is also to: 1. Be sure to always provide adequate supervision to all end-users. 2. Be sure to instruct all end-users of proper usage. 3. Be sure all supervisors and personal trainers who instruct end-users on equipment use are properly trained and know the function and importance of every adjustment and setting. Also, be sure these trainers provide proper instruction to end-users on the fundamentals of strength training.
Dec 01, 2008 | Body Solid Cam Series Ab/Back Machine
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
