Question about Canon imageRUNNER 3300 All-In-One Laser Printer
In Canon IR3300 model dust formed
Dear sir, In Canon IR3300 model dust has been formed near drum cleaning BLADE. I remove and clean the dust from cartridge after I taken less than 200 copies to create this problem again and again. The printing also come with long shading. why the above problem is comming? How to clear this problem?
My E-mail ID: newprintpoint@gmail.com
    Sniper:
  • 77 Answers
You must change your cleaning blade
Posted on Jul 30, 2010
  • 1 more comment
  • Copytech
    Copytech Aug 28, 2017
    Bt I already changed my cleaning blade and new pcr, drum also
  • Copytech
    Still I'm facing this problem
  • Copytech
    Please tell me the solution
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
Model ar5516. Why is drum not cleaning?
Sir,
Did you prime the cleaning blade with toner when you installed it?, and did you ensure the new cleaning blade did not flip!!!!, re-check the new installed cleaning blade, place a small amount of toner from the toner bottle on the drum along the whole drum. and using your hands at both end of the drum DO NOT TOUCH THE DRUM" turn just a 1/4" CCW (To ensure the cleaning blade is set) then CW to see if the toner is removed. your drum might need to be replaced and or the fuser unit have a example of the copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 28, 2015 | Sharp Office Equipment & Supplies
Canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
Sir
Pl. do the waste box cleaned-check the waste sensor-the harness.
Dec 21, 2014 | Canon IR 3300 Digital Copier
Copy light
Hi
When you were replacing the drum did you tuch the drum surface?Best would be that you take some toner on piece of cloth, and polish the drum, while turning it in good direction, that the cleaning blade can clean it.After you must let it copy about 50 copies.
You can try to replace the whole drum unit cexv14, or clean the laser unit.
Also could it be that the toner unit, or toner cleaning blade are not properly distibutes the toner accross the developing/toner cylinder.
Nov 26, 2009 | Canon iR 2020i Laser Printer
Brother says "Dust on Drum" wont print, and when does the page has two black lines down the middle
Yes some of dust have your printer drum unite.Open drum and clean it then solve your problem.
Nov 12, 2009 | Brother MFC-7820N Printer
Np 6045 Canon photoopier drum scretch in the durm hwo to solve
Change the OPC drum and the drum cleaning blade.
Sep 27, 2009 | Canon NP 6050 Copier
Need to change cleaner blade on drum
Remove drum unit, remove Drum, remove blade (2 screws)
** coat the new blade with some toner, or it will flip, when the drum start to turn, due to the friction. And always manually rotate it yourself prior to re-installation to make sure it is ok
Apr 28, 2009 | Canon C330D Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Replace drum cleaning blade
take the toner hopper off take dev unit out lower handle on umber one unit remove screw in drum pin remove primary charge assy remove screw lower right of drum frame remove screw upper left frame un plug connectors unit slides out
Oct 31, 2008 | Canon NP 6545 Copier
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
252 people viewed this question
Clive
Clive
old marine
old marine
