Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
Our pump was running dry for at least a day because a leak dropped the water level below the skimmer. it runs on 220 and sounds like it's running but no water movement in or out. i need a new pump, right?
    Top Expert:
  • 12,744 Answers
Not necessarily if running may need to be bleed[air bound and need to let out air ]or may need to be primed if there is a bleeder on pump housing un- screw to release air until water runs out --- if still no water pumping may have damaged the impeller depending on ur pump may have to only replace impeller or pump housing
Posted on Jul 20, 2010
How do I stop my swimming pool from leaking water?
id look 4 a leak someplace in the suction side of things when pump runs it draws air in hole so No leak but when pump shuts off No draw just water and it leaks out
look for hairline cracks in skimmer bottom and bottom suction lines , Might require scuwba equipent to see ?
Nov 03, 2014 | Pool & Spa
Pump wont turn on
make sure heat maintain is off if ok new pump
Apr 04, 2014 | Pentair Pool & Spa
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
I'm trying to drain a pool that's Ben sitting for years full of nasty water. Pump works and operates but the fill pot on the pump itself will not stay full
Sounds like you're trying to pull water from skimmer and main drain. Soon as the level goes down, it sucks air from skimmer. Turn off skimmer line. If that's not possible, then cut off input side of pump(front pipe) and run new line to pool. Just lay it on top of ground and keep it below top by a couple of feet. This will stop all the **** on the bottom from plugging up the pump.
Mar 08, 2011 | Pentair Pool & Spa
I just had a inground pool built 2 weeks ago and I suddenly lost about 10 inches of water in my pool and the svl56...sounds like the motor is running but I don't see water bubbling in thewhite...
it sounds as if your skimmer is leaking, either from the plastic body, or from the faceplate gasket. to confirm this, shut off you pump and let the water settle. put your garden hose in the pool so that water is being added. get a container of food coloring, and slowly disperse it around the faceplate, and inside the body of the skimmer, and see if it gets drawn in anywhere. this will indicate your leak location. then call your installer, 2 weeks is unacceptable! good luck!
Aug 11, 2010 | Waterway Svl56 1.0 Hp 1 Speed Energy...
After I drained and cleaned my "Jacuzzi 220" I filled it and got a FL2 code and now only half my jets work. Is it as simple to fix as disconnecting the pressure switch and reattaching? Thanks, Richard
You probably need to run water into the skimmer to force air out of the suction line. sounds like one of the pumps is not priming due to air lock. When you drain the spa, get into the habit of running water into the skimmer when you start refilling it.
You can get it to prime by loosening the discharge side pump union until the air is out, then re-tighten. The FL2 code is a "flow" error for the circ pump.
Oct 25, 2009 | Pool & Spa
My pump will surge on, run for a while and shut off, then start up again. Unplugging and replugging makes no difference. What to do?
Check to be sure water level is up where it belongs then check to be sure your skimmer weir door is free. If this is stuck water in the skimmer will run the pump for a moment then the water will run around the door and fill the skimmer to start the cycle again.
Aug 10, 2009 | RTO Cal Torpedo Pump 7500 Gph
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
303 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
