Question about RIM Blackberry 7130e Smartphone
7130e bluetooth won't enable - RIM Blackberry 7130e Smartphone
  • AKHTAR KALIM
    AKHTAR KALIM Jul 21, 2010
    There is some hard ware problem in your device , so you have format the device and re try to enable Bluetooth. Follow the below instruction Screen menu > manage connection > checkmark on ?blue tooth? Save.
  • econdon36 Jul 21, 2010
    When I go to the options and try to enable the bluetooth, it won't change the status from disable to enable.
  • 85 Answers
There is some hardware problem in your BlackBerry , so you have to format you device and re enable your blue tooth,
Or follow the below instruction
Screen menu> manage connection> check mark on <blue tooth>
Save
Posted on Jul 21, 2010
Bluetooth inspiron 1420
check the bluetooth driver is installed
Dec 04, 2011 | Dell Computers & Internet
Please I want to configure my blackberry phone 7130.
If you want to configure your unit for Blackberry service inquire with your Telco provider on activating the service since Blackberry units are configured via the service books. Service books will enable your E-mail, Web Browsing, MMS and BBM.
Apr 26, 2010 | RIM Blackberry 7130e Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to transfer music using bluetooth of blackberry7130g
There is no SD memory in the 7130g, so you would only have 64mb max for songs (I am sure some of that is being used for applications).
However, if you want to transfer ringtones from a phone with bluetooth you can pair with that phone and when they send the file, you get a prompt to accept it.
Oct 14, 2009 | RIM Blackberry 7130e Smartphone
I have a cricket fashed blackberry 7130e it always says data connection refused on the screen. can it be fixed?
I have a flashed Blackberry 8330 for Cricket. I know to get the phone and SMS working is pretty easy. There is a second more complicated step to get the data working. I flashed my phone myself, but I couldn't find the solution for the data.
Oct 09, 2009 | RIM Blackberry 7130e Smartphone
Blackberry 7130e
again... please see what happens if you trying calling with your hands free ear buds... is it still happening??
Dec 22, 2007 | RIM Blackberry 7130e Smartphone
RIM Blackberry 7130e Smartphone Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
