Question about Akai PT4298HD Rear Projection Television
Akai pt4298hd rear proj tv
Power button comes on and then timer light flashes a few seconds. you can hear a temporary attempt to power up but no picture and no sound.
  • bigdaddydtg Apr 22, 2008
    this seems to be a very common issue. any recalls?
Unit may be in timer mode. Check menu settings
Posted on Apr 22, 2008
AKAI rear projection TV won't turn on
possiblity convergence needed...
main power board malfunctioning
contact akai service center
Apr 26, 2010 | Akai PT4298HD Rear Projection Television
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Akai pt4298hd
Look at AC power supply board they are bad about poor solder joints resolder thyrisitor on board.
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
PT4298HD Power does not work
The power button is not working, the light will flash however, nothing appears on screen
Oct 29, 2008 | Akai PT4298HD Rear Projection Television
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Set won't come on
FWIW... my Akai PT4298HD just quit also, same symptoms. Just 2 years old. Will continue to search for solution.
Sep 13, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
174 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
