My spare Ricoh AP3800c has decided to show a SC541 warning, I understand that has to be reset in 'Service Mode' is it possible/safe to do this myself? if so can anyone give me an idiots guide to doing it? Thank you
  • myrfin Jul 21, 2010
    My spare Ricoh AP3800c has decided to show a SC541 warning, I understand that has to be reset in 'Service Mode' is it possible/safe to do this myself? if so can anyone give me an idiots guide to doing it?. I have got as far as getting into Service Mode and down to
    Machine/datalog/counter reset. I have pressed enter at Oil supply: I got the following readout '00000000 sheets'
    and Fuser I got the following readout 02799784
    I pressed enter but no changes on either.
    Any suggestions Thank you
    New Friend:
  • 97 Answers
Hi, if you're still needing help with the 3800c, the full manuals are available here :
michelsplace.fr
Posted on Sep 08, 2011
  • 4,281 Answers
For that you need to reset your printer settings. Press menu button of printer then enter in settings many then restore defaults all settings . Also pull ink cartridge from printer then reconnect then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 21, 2010
    Hi, thank you for the suggestion, the Ricoh ap3800c does not have ink cartridges, it a laser printer. can you clarify . regards
  • It has toner try with another toner then check.
    Also make sure for paper jam try to reset all settings to factory defaults .Then it will work fine.
    Genius:
  • 1,478 Answers
Power off the printer, wait a while and power on back, while the printer is loading, unplug the printer from the AC power source and wait for some minutes before you plug in back and power on. This should reset your Ricoh AP3800c printer. if problem persist, follow the below procedure.
Hold down the two arrow keys and count to 5, hit the enter key, the machine should be in service mode if nor repeat. use arrow key and scroll to machine press enter scroll to data log press enter scroll to pm counter reset press enter, scroll to fuser oil press enter and execute this mod Please. DO NOT GO INTO ANY THING ELSE or you could do serious damage to your machine!! If your machine has a Copy feature expander you must press Clear mode, Press 1-0-7 and then hold down the stop cancel key 4sec. go into copy mode press 7-804-809 press execute button again Please DO NOT GO ANY WHERE ELSE as damage can be done to your machine.
Take care.
Posted on Jul 20, 2010
  • 1 more comment
  • myrfin Jul 20, 2010
    Hi thanks for that, I got to PMCounter ,enter
    when I scroll the only entries that relate to 'fuser oil' are 'Oil Supply, and 'Fuser', Follwing your warning I did not press these, which of these is the one that I want? regards John
  • Jimoh Adeleke Muyideen Jul 20, 2010
    From the two options, is it that the second option do not have oil at the front? because it is suppose to have it,if not, Use the oil supply.
    Take care.
    Hi I tried both oil supply : I got the following readout 00000000 shhets
    What am I doing wrong? , thanks
How to remove SC542 in ricoh SP100 SF
Enter service mode (hold down up/down for 5 seconds then hit #) service mode 5-810 to reset (fuser problem)
Apr 27, 2014 | Ricoh Aficio AP3800C Laser Printer
How to enter service mode for ricoh mpc 3003sp
YOU NEED TO PRESS C BUTTON(RED) LATER PRESS KEY 1 , KEY 0 , KEY 7 & HOLD THE YELLOW KEY FOR SEVERAL SECONDS, THEN THE MACHINE WILL ENTER SP MODE
Sep 23, 2013 | Ricoh Aficio AP3800C Laser Printer
Sc556
To reset fuser SC codes you need to enter Service Programme Mode and reset SP5-810 to 1, then turn the main switch off and on again. If you need help on entering SP mode etc. then take a look here.
Feb 27, 2012 | Ricoh Aficio AP3800C Laser Printer
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Service Mode
The service mode for an AP3800c printer only is different from the copier version. push down the up and down arrows together for a count of 7. Then push the enter key (#). The screen should now show "engine" in the window. If you are resetting a function you will need to arrow down to "service" then push enter (#) again. Use the escape key to exit from the sub menus. To exit back out of SP mode you will need to select "end" at the top line menu pressing enter to accept.
Nov 18, 2007 | Ricoh Aficio AP3800C Laser Printer
The PCU Reset procedure needed
switch the machine off at the switch hold down online and escape while switching on the switch , hold the buttons till you see service mode on screen , you need to go to engine , then drum , there you will find the setting to reset the pcu , or under data log is a function pm counter clear if it is giving you replace pcu on the screen
Nov 01, 2007 | Ricoh Aficio AP3800C Laser Printer
228 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
