Question about D-Link DI 514 Wireless Router (DI-514)
D_Link 615 wireless router hit and miss.
Wireless connections work at best 30% of time. All new computers can detect wireless router but connections are far and few between. Can anyone provide potential fix?
  • 3,289 Answers
There are quite a few variables that can affect signal quality and ultimately the ability to connect. Of course, having the proper SSID and security credentials (or "keys") are required. The type of security employed on the router must be supported by each device that needs access. An example is a device that offers WEP security will not be able to connect to a router that runs WPA or an even more robust security system software running on it. Since you're able to connect 30% of the time - I'll assume that you have the proper credentials in place on all devices expected to connect to the router, with one exception: Make sure you're connecting to your router. Verify the SSID of your router. You may be close enough to a neighbor's router with a different SSID on some devices and are attempting to connect to it - with the wrong credentials.
Next is location. Locate the wireless router in a location that is central to the devices that will connect wirelessly. A location on the first or second floor is better than a basement location - unless all the devices to connect are located in the basement.
Consider the surroundings. WiFi is a radio signal that operates on 2.4 Ghz. This is the same frequency as many newer cordless phones, baby monitors, etc. All off these devices are competing for "space" on that frequency. It's like driving between to nearby cities that have a radio broadcasting on 98.5 - one plays music and the other is talk radio - you are unable to listen to either really until you get closer to one or the other. See if these types of devices are limiting the range of your WiFi by unplugging the AC power from these devices - and on the remote handsets - remove the battery. Power them up one at a time to see which is reducing the signal. You may be able to experiment with a new location for this device - or discontinue its use.
What type building materials? Obviously simply wood and drywall is relatively easy for WiFi signals to penetrate, but multiple layers of it and concrete, aluminum, brick and others are significantly more challenging. Experiment with relocating the WiFi router to see if there is a better spot for it - I know it's easier said than done, but that's the way it is.
Antenna upgrade. Some routers have detachable antennas and can accept more powerful antennas. Some manufacturers sell them for their products, too. LinkSys at one time sold a pair of 7 db gain antennas for about $50 or so. These antennas can and do make a difference - but only if your router supports a removable antenna.
There's a lot to digest here - hopefully one or more suggestion will allow you to connect reliably again. Please rate this response and good luck!
Posted on Jul 20, 2010
  • Steve Jul 21, 2010
    Oh - I forgot to mention.. if you can upgrade your antenna(s), choose from those with higher or greater value of gain in decibels (db or dbi) as they are more powerful than those with lower or smaller values. Example: antenna with 7 db gain will send and receive signals better than an antenna with 4 db of gain.
Cant connect to d-link DIR-615 wirelessly, can someone help me?
What is the operating system on your laptop?
Can you access the Internet if you connect the computer to the router with the Ethernet cable?
If the wired connection is working then it must be the problem with the wireless network.
If the wired connection is also not working then you may need to reset and reconfigure the router.
If only wireless is not working then you can try creating a new wireless network and then connect your laptop to the new wireless netwok.
I can suggest you a website which may help you for Home network connection.
May 20, 2012 | D-Link DIR-615 Wireless Router
My DIR-615 Dlink router always has the Orange globe. How am i supposed to fix this, the modem works perfectly fine as i tersted it without the router and internet works. But my wife needs the laptop and...
In the web interface of dir-615 switch it to router mode, adjust wan connection (username, password... depend on your Internet provider, in fact, it is easier to ask their tech support to provide all necessary information) then configure wireless network.
May 19, 2011 | D-Link DIR-615 Wireless Router
I am connected to a DIR 615, it says I have wireless connection but it won't connect wireless, if I connect a cable it is fine??
Hi mike63771,
All you need to do is to set it up properly. Make sure that the router is connected to the computer using an ethernet cable so that the computer will be able to communicate with the router. Then open a browser type 192.168.0.1 on the address bar. The default username is admin and the password is blank. Go to the Wireless Settings Page then check the SSID or Network Name and the Network Key or Passphrase. Now try to connect to your computer. Click on Start then click on Connect To. Select your Network Name then if it ask you to enter a password enter the Network Key. You can personalize the network key on the router settings page.
Rate me if this helps so i can help other.
Thanks for using Fixya.
Feb 02, 2011 | D-Link DIR-615 Wireless Router
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
New laptop won't connect to internet thru D-link 615 even tho main computer works thru D-link 615
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 26, 2009 | D-Link DIR-615 Wireless Router
How to configure D-Link Wireless Router 615 on LAN ?
you need a cat 5 or better to work fine, and if you have turned mac filter on, please check/add if needed your laptop to the network, best is to use dlink given cd, with has auto-detect devices function inside, then adjust security setting manually
Sep 22, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link 615 stopped connecting with wireless
If your laptop is not detecting the wireless router, can you try to get the laptop closer to the router ? If you have done that already, I would suggest you to try and power cycle the router once. If that doesnt work either, try to reset the router. Hope this helps
Thanks Ranjit ranjit@supportminds.com
Jun 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
D-Link DI 514 Wireless Router (DI-514) Logo
96 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
