Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips magnavox model# 9p5531 c101 no sound coming from tv when plugged from "direct tv" reciever to audio input on back of tv. But speakers work when i connect speaker wire from the speaker connections on back of tv to stereo multi channel reciever
  • resendes Jul 20, 2010
    thanks
  • Philips Master
  • 6,993 Answers
firstly, check your audio wire to make sure its still good because the audio wire might be defective.
Secondly, check the volume of the "direct TV" and makes sure its not on mute.
Also, to be sure the audio input of your TV is still functioning, connect a DVD player to your TV with another audio wire, and observe if there will be sound.
Take care.
Posted on Jul 20, 2010
    I've tried to connect a dvd player to it as well and still no sound. Also check the mute and that's also not the problem. I hooked up my stereo reciever to the tv yesterday for the first time and heard a loud buzz sound and immediately unplugged it. When i attempted to put everything back to its orginial way, I then had no sound from the audio input. But, again the speakers are definately working b/c when connected from the speaker connecters on back of tv to the reciever, there is sound.
  • Walesarumi
    Walesarumi Jul 20, 2010
    okay, connect a local antenna using the RF at the back of the TV and if there is still no sound, then the sound IC/chip of your TV is bad and needs to be replaced for the TV to bring out sound again.
    Let me know what happens after using the local antenna. There is every tendency the your TV sound IC/chip is defective.
    Good luck.
    President:
  • 1,099 Answers
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker.If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker.
Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector.
If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/humm pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Hope this helpout...
How do i connect my lg42lh2000 to my lg ht302 receiver so that the sound from the tv can be heard through the recivers speekers
you will need:
rf modulator.
coax cable.
video cables.
run audio cables from yourmusic source to the reciever that should work but if your music source is away from the reciever then get an rf modulator and put your music source by your reciever and the put thevideo cable from your music source to the rf modulator and tthenrun a coax cable to the tv and then run the audio cables from the music source to the input on the reciever. for example i have my direct tv box sound running through my reciever and speakers, and to have musicfrom the direct tv box going through my speakers i put the audio cables from my direct tv box into the audio input on the reciever and then the video cable into the rf modulator and then from the rf modulator i ran a coax cable to my tv then i had my sound from the direct tv box going through my reciever and the video on the tv.
plz tell me if this works :)\
Aug 05, 2013 | Audio Players & Recorders
How do i connect my reciver to my lcd hdtv so the audio is coming from my speakers not the tv speakers.
kindly get four audio RF connection wires look for the audio output on the front or back of your tv. one of the output connection is white the other is red.look for the same connectors on your reciever the same colour.but they are marked input.plug the output wires from your tv to the input connection of your reciever.if you have separate speakers, connect the speaker wires from the output connectors of your reciever so you can get sound comming from your tv through your reciever,good luck.
Sep 25, 2011 | LG Televison & Video
I am wondering, I would like to hook up a very small pair of speakers to a ts3260c magnavox television, there are out puts on the back that are rca connections. i was wondering if when i plug in rca...
They will stay on if you are just hooking up the speakers. If you want the TV speakers to shut off, use a stereo system or something to switch audio inputs.
Jun 02, 2011 | Philips Magnavox TS3260C 32" TV
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
Magnavox 20MC4304 connection to receiver
your set has a coaxal DIGITAL output so you must have a coaxal digital input to your reciever and that input must be assighned in the reciever to the selected input. page 10 of your manual explains how to hook up to the tv. your receiver's manual will tell you how to assighn the coax input.
Mar 09, 2008 | Philips Magnavox 20MC4304 20 in....
2 tv to repair
You can check any 5v input to the microprocessor and sound is the audio IC whether have any voltage input.You can try to troubleshoot but please be careful.I don't have your model schematics but oher philip models.
Regards
alan
Feb 06, 2008 | Philips Magnavox 27MS343S 27" TV
Getting the speakers to work with the TV
Yupp(depending on how old your stuff is) I will assume your using cable and using your tv to switch the channels. Look at the back of your tv there should be a audio output, plug some RCAs (red, and white) into the designated spot and now look on the back of your reciever, it should have a tv input, if not just a input. After that is done turn on the tv and put the reciever on the channel that you plugged it in. For example if you plugged the rcas into Tv input...then you would set the reciever to TV
Mar 25, 2007 | Koss KS2503 System
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
