Question about GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH
BUZZES I have an GE Deep Freezer model CB15DM when you turn the switch to on it just buzzes the buzzing is coming from the piece where the temp selector and on off test switch is thanks
  • 166 Answers
This sounds like the temperature monitor is alarming because the temperature has not cooled down enough yet in your freezer. turn the monitor off until the freezer reaches proper temperature then you can turn it back on.
Posted on Jul 20, 2010
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
Freezer temp. gauge buzzes daily, says dfd, nacp. Have to reset daily. What's wrong
Firstly, anything new comes with a warranty and will need to be repaired by an authorized tech.
Next, follow this link to help assist in diagnosis.
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 10, 2017 | Victory Freezer Freezer Reach in single...
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
When you turn the switch to on it buzzes constantly
The buzz is the compressor trying to start and not getting started...it could be mechanically broken or the start cap and relay could be bad...
here is a tip that will help you with that...
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Feb 26, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Jun 29, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
GE 14.8 cu. ft. / 419 liter Chest Freezer FCM15DPWH Logo
557 people viewed this question
Top GE Freezers Experts
John Tripp
John Tripp
AJMAL KHAN
Gil Shultz
Are you a GE Freezer Expert? Answer questions, earn points and help others
