Question about Vacuums
We can't get the Harbor Breeze Receiver # UC7067RC ceiling fan to work or the lights - there is power to the unit.
3 Suggested Answers
karns
  • 122 Answers
SOURCE: The blue neon light on
it may be the little board that the neon bulb pluggs into. check Ebay for a replacement. Ebay usually has what I need for stuff.
Posted on Aug 13, 2010
sean1dave
  • 7 Answers
SOURCE: Need white translucent globe for
I believe Harbor Breeze is sold through the Home Depot. Any well stocked Home Improvement store will carry a great selection of replacement globes for your light.
Posted on Mar 07, 2011
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
My wall ceiling fan's control unit UC 9051T failed. Light switch button does not work. If I replace it with some generic universal unit, do I need to replace transducer located in the fan housing also, or...
First, you didn't say you checked that the bulb worked. Is that burned out?
If bulb is ok, you will have to make sure the switch is matched with the fan (ususally a set of 4, 6 or 8 micro-switches have to be set the same in both switch and fan to be on same frequency of communication - even if you have an exact US 9051T controller).
A whole new fan is not too expensive ($100) and may be best route if you use the fan alot and it is over 7 years old - just an option.
Also, just because the light doen't work doesn't mean it is the switch transmitter that is broken, it could also be the receiver. Call the company on the website below - they will either tell you how to check or you can send everything to them and they will check for you.
http://www.eceilingfans.com/
Sorry for making it so difficult - I hope it is just your bulb.
-Mark
May 05, 2011 | Vacuums
Hi. I have misplaced the remote for my Aloha Breeze ceiling fan. How can I get a replacement?
Look on this site http://www.searspartsdirect.com/partsdirect/brands-products/Aloha-housewares-Inc-Parts/Fan-Parts;jsessionid=EhpYk2SBMad9Blbgl+MKrg**.pdapp401p2 to see if they have the model number and part. You'll probably find that the replacement part costs near as much as the whole thing did tho.
Mar 22, 2011 | Vacuums
Need white translucent globe for Harbor Breeze Ceiling Fan to cover light. Globe fits to fan base with 6-1/4" Inside diameter mounting ring and is secured with three thumb screws.
Mar 07, 2011 | Vacuums
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Mar 06, 2011 | Vacuums
My hunter ceiling fan is not working and according to hunter technical support, I need to replace the remote control receiver (part # 8511204000) at a cost of 50.00 plus shipping.is there a way to by-pass...
If the product did not come with a manual control on it then yes you will have to use the remote. However, if the replacement remote will cost nearly as much as the ceiling fan itself you could simply purchase a new fan.
Feb 28, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Oct 11, 2010 | Vacuums
The blue neon light on my harbor breeze fan no longer works. Where can i get a replacement?
Aug 12, 2010 | Vacuums
Vacuums Logo
292 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
