Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
When i turn the key on the mower the engine turns but does not want to start
    Sergeant:
  • 299 Answers
If theres a safety mech's on them make sure blades and pto are disengaged, also sometimes you have to depress clutch or have the parking brake set, just like if you are mowing and decide to stop and put it in nuetral if the blades are lowered and pto engaged when you leave the seat the motor will cut off. if that isn't it make sure your spark plug is pushed all the way on.
Posted on Jul 20, 2010
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Ford 601 tractor starting problems
Ok lets start at the start on this one. Which of the following best describes the situation?
- Turn key and nothing, no lights on dash, no noises.
- Turn Key and weak lights that flicker in start position and clicking noises
-Turn key, strong lights but little to no movement from engine or a strange noise comes when key is turned
-Turn key, strong lights, engine turns over but will not fire.
A tractor is a complex piece of machinery and something like an engine that will not start could indicate one of many problems, with some trial and error you can generally work out what the problem is be we need somewhere to start.
Aug 03, 2013 | Garden
Rally ride on lawn mower not starting. briggs and stratton 12 hp engine. battery fully charged but engine not turning when ignition key turned
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
May 03, 2010 | Garden
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Trouble code ch6 oil on hour meter
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
May 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
164 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
