Question about Asko T701 Electric Dryer
The dryer starts but immediately stops
Cleaned filter; i believe there is a reset button? which hopefully could fix the problem? where is the reset button located please
  • Asko Master
  • 2,605 Answers
Hello and welcome to Fixya. To address your question regarding the "reset", the manual reset hi-limit cut-out at the back of the dryer. It`s located on the back panel about 1/2 to 3/4 the way down and will look like a small round black rubber button. Push it to see if it "clicks" and then try your dryer. **What to look for if it`s tripped... 1) Plugged venting - make sure your venting is clean and clear of lint or un-obstructed where it exhaust`s outdoors. ( I realize you mentioned this, but check it thoroughly ). 2) Plugged lint screen - ( part # 8061812 ) This is especially relevant if one uses fabric/static sheets as they contain wax...especially lesser name brand sheets. You can clean the lint screen by removing it from the door and with some mild soap and hot/warm water wash it...an old toothbrush works well for cleaning it. Careful not to rip the fine screen. 3) The blower wheel/fan impeller ( part # 8055200 ) attached to the front of the motor which moves the air through and over the clothes in the drum may be loose, broken or covered in lint, hence causing the hi-limit to trip. 4) A faulty heating element ( part # 8063808 ) can also cause the hi-limit to trip as well. If the element is shorted to the casing it will not cycle "off" via the 115°C (part # 8008807 ) cycling thermostat, thus cycling off via the hi-limit 150°C ( part # 8008487 ). Let me know how that works or if you`ve already tried that. If it is tripped, resetting it may only temporarily resolve your problem since it is usually tripped due to venting or heater issues. If it is not tripped let me know and we can explore other possibilities. good luck. macmarkus :)
Posted on Jul 20, 2010
I have a 5 year old LG front loading dryer, model # DJG2524W. When I went to start to dry a load, the dryer started, and then stopped after only a second or two. The check filter light was flashing. We...
Hi
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Dryers
We used our dryer yesterday and everything was fine. I built the box my self to put dryer on. Afterwoods my dryer does not get hot. Its tumbling, but not heating up. Its saying check filter. And that is...
It could have kinked the hose behind the dryer and it is not venting now. Also while you're looking make sure the vent is not stopped up. If the dryer can't vent out the back properly it will overheat. Hope this helps. It would definitely be the easiest fix. Good luck
Apr 18, 2011 | LG DLE5955 Dryer
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Asko T701 Dryer - Dryer Start Button
This would have to be your door latch, in my opinion. The door simply is not holding in the button.
Dec 07, 2008 | Asko T701 Electric Dryer
Dryer keeps stopping - check filter light on
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
May 13, 2008 | LG DLG2525S Electric Dryer
My Asko T721 Electric Dryer is having drying troubles
Here's the answer:
The dryer has a thermo protection "fuse" that pops-out when the lint filter is not cleaned and air will not flow properly. When the airflow is restricted the dryer gets too hot and the "fuse" pops. Then it will not run unless you stand there and hold the start button in. As soon as you stop pressing the button the dyer stops running.
Clean the filter ESPECIALLY the "internal" filter. This one is behind the lower skirt of the machines face. There are two Torex head screws (T20) to be removed and the skirt comes right off.
Inside you see two red handles that you turn to open the filter door. Open the door and pull out the filter. It is a long metal finned box. Take it to your bathtub and run a ton of water through both ends to remove the lint inside. You'll be surprised at how much.
O K now let's "fix" the "fuse". Here it is likely you will need to pull the machine away from the wall. The fuse is a black plastic button about the size of a penny. It sits in the center of the machine's backside. It faces up a bit and if you have clearance you can reach your arm over the machines top and press it "in" with a finger. It clicks when you do so. This part is a no brainer. The dyer will now start properly.
The hard part to all of this is pulling the machine away from the wall since like me you probably have it sitting on top of an Asko washer. Take your time. You can do it.
Jul 02, 2007 | Asko T721 Electric Dryer
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Asko T701 Electric Dryer Logo
250 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
